VCR Won't Record Sound
Hi! I have a Quasar VCR Model VHQ440. When I record a program it will record the video but not the audio of the program. However if I play a tape that was recorded in my other VCR, the sound works.
I did run the head cleaner through the VCR thinking it might just need to be cleaned, but that didn't do anything.
Any ideas?
  • Televison & ... Master
  • 5,318 Answers
Some VCR have the ability to record sound from another source. Check the sound settings and record settings to make certain it has not been switched to another sound setting.
Posted on Oct 03, 2017
3 Suggested Answers
  • 476 Answers
SOURCE: VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Posted on Feb 22, 2008
  • 275 Answers
SOURCE: VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Posted on Dec 02, 2008
I have a Quasar VH6200 VCR. Can it be connected to a new TV and be able to record TV programs. I have connected it but it won't record. What can I do?
I have the same machine and the same problem as you do. Apparently, because this model has a hardwired, built in calendar, it experiences a "Y2K"-like problem and will not record (even manually!) when you either try to program a date that is more recent than 2008, or the machine's present date "hits the wall." The solution is to program a year that is identical to the current year. Example: day and date-wise, 2014 is identical to 1997. So entering the correct month and day, but using 1997 for the year entry will allow normal operation with correct day/date timer operation and the stupid CPU will be none the wiser. As for using this machine with modern HDTVs, there should be no problem as long as the TV has standard analog A/V jacks. For recording the machine would need a source of standard-def video, either basic cable TV or a digital converter box if using over the air signals. BTW, 1998 is a match for 2015, so the above solution will be good for two years. After that, just look up a leap within 1990 to 2008 year that matches 2016.
Feb 05, 2013 | Quasar Televison & Video
I cant program my quasar vcr to record
the processor has some garbage in it do to a small power surge and if you unplug the unit from the wall for 40Min, it will reset back to normal.
Nov 26, 2011 | Quasar VHQ400 VHS VCR
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
What cord do i need to watch a video from my Quasar Palmcorder on my tv. I don't have a vcr anymore, the model is VM-L450.
hi; if you have a audio video out[rca type cable that
you can use it will be fine you plug it in a/v input on your tv theres no need of a vcr exept if you want to record what you have on the camera or you can use
a dvd burner to save it on a dvd disc...
hope that will help you..
Mar 03, 2010 | Quasar VM-D51 Camcorder
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Record tv
The VCR will have to be on channel 60 as well in order to record a program. Hope this helps....accordianman
Apr 25, 2008 | Quasar VHQ400 VHS VCR
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
