Question about Frigidaire Dishwashers
My 18 inch MDR251RER Frigidaire Dishwasher made a start up sound and then there was a plume of smoke behind the unit it was not running at the time?
  • 3 more comments
  • pblumen544 Jul 30, 2009
    The fuse in the house fuse box is not blown. the dishwasher does start up and the plug is secure any other ideas?
    My MDR251RER Frigidare made a noise like it makes when changing cycles and then there was a plume of black smoke behind the unit. the unit was not running it did not blow a fuse in my fuse box it did not trip the fuse it is getting power and the plug is secure?
    If that is the case is it worth repairing or get a new one the drain alredy does not drain properly
    What is a PCB
    Yes
    Novelist:
  • 123 Answers
If the machine is runs with no burning smells, you may be better off removing the power plug and pulling the machine out, You`ll probably find that there`s something behind the maching that`s smoking. If it is smoking, and it works, you`ll probably find that one of the multi plugs that connect the PCB to the motor etc is arching producing the foul smell and black smoke. Ian
Posted on Jul 30, 2009
  • Ian Percy Jul 30, 2009
    In that case you may be better off cutting your losses, but double check that it is indeed the Dishwasher that`s spewing smoke out, Are you sure that there`s nothing behing it or under it that could be producing the smoke. I`d hate you go out and buy a new one, only to find that there`s still smoke coming up. If you`ve got wooden floors, is it not coming from under there?? Ian
  • 296 Answers
Hi, well make sure the dishwasher is getting power. Check your fuse box for blown fuses. If you have circuitbreakers check to see if they are tripped. Make sure the dishwasher's plug is secure in the outlet. The problem could be the blown fuse.
Thanks! mannu_rakesh
Fixing a Frigidaire Dishwasher (FMB33ORGCO)
Hello Paulus!
From what you have described your Frigidaire dishwasher is will not start and you have performed a reset. This could be a possible issue within your control panel or wiring harness. Since it could be an issue within the electric components I would suggest you speak with a professional technician, they would have the appropriate tools needed for proper disassembly of your dishwasher. Hopefully this is helpful. -Matt
Nov 29, 2015 | Frigidaire 18 Inch Dishwasher White ,...
Frigidaire 18" dishwasher arm is not spinning, and dishwasher is making a very loud noise.
Hi Ellie, this is AP!
I understand you are experiencing some trouble with your Frigidaire built-in dishwasher. Without knowing the exact model number I would assume there are two spray arms on this dishwasher, are both arms not moving or just one? Keep in mind that some dishwashers have two spray arms that turn at alternate times. They will never move at the same time. The changing of the arms starts at different times depending model and will continue through the end of the selected wash cycle.
If you can provide the model number for the dishwasher I should be able to provide you with the instructions to remove the spray arms or you could contact the manufacture they may supply it to you also. You could also apply rinse aid to the junction between the spray arms and mount to see if it will relieve the arm to spin. If not, please reply back with the model number so I could provide a more educated response.
Best Wishes,
Mar 30, 2014 | Frigidaire 18" Built-In Dishwasher
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
B&S 300 series 148cc walk behind side discharge mower emits white smoke on start up
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 04, 2012 | Cars & Trucks
Single cylinder yanmar diesel engine on log splitter back fires out of exhuast & blows out black smoke
Engines runs for a couple of seconds then loudly backfires with a flash of flame out of the exhaust followed by a plume of black smoke. Then runs sort of ok for a couple of seconds then repeats the backfire again AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Apr 21, 2012 | Cars & Trucks
I have a Simplicity model 1692762 with a 16hp Briggs and Stratton. The mower blew large plume of white smoke three times while cutting grass over a period of 10 minutes. Engine seemed to lose some power...
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
May 27, 2010 | Garden
Dishwasher smoking
nothing specific until you get a technician to properly diagnose the fault
Aug 19, 2017 | Frigidaire 24 in. FDB1050REC Stainless...
Hooked up new 18 inch frigidaire dishwasher, sounds like the motor is running but not filling, making kind of a gargling weird noise
If it's new call a Frigidaire servicer for wty service. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire portable dishwasher wont start
check the outlet where you plug this dishwasher into make sure you have power to it you may have a popped breaker. reply back if this is not the cause.
Nov 18, 2008 | Frigidaire 18 in. FDR252RB Built-in...
Dishwashers Logo
149 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
