Question about Frigidaire Dryers
Error e 68 pops up and dryer turns off. Doe sthis
Error e 68 pops up and dryer turns off. Does this mean my card must be replaced?  This is an Affinity Front Loading Dryer.  I am in a very remote location and no service technician can get here.  COuld any one walk me through the repair?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. E 68 error means that there is a leakage of current to the ground on heater or fuse opened. Also check the resistance of the NTC which should be around 50K ohms. If not then you need to replace the water inlet valve assembly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 30, 2009
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 | Dryers
I HAVE A EURODESIGN DRYER BOUGHT IN '03 I now have error 68 message and dryer stops - anybody know what this means - cant find it in the manual. thanks
It means it has a stuck button.
I'm taking it that it's a Fridgidaire.
on the door you should have a model number that looks like this
AEQ6700FS .
http://www.searspartsdirect.com/dryer-repair/error-codes/frigidaire-dryer-error-codes.html
Once you find this and you need a manual goto
Browse Products
Apr 17, 2015 | Dryers
Machine error 50
On a Brother printer Error 50 typically means that the Fuser is malfunctioning.
Turn the printer off for about 5 minutes. Then turn the printer back on and wait for about 10 minutes. If after 10 minutes the printer doe not recover, you will need to replace the fuser unit. May be more economical to replace the whole printer.
Jun 30, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Card would not eject properly
error 68 mean the card is jam in the print station or in the flipper area.
you either clean the card part and flipper very well.or you may need to change it.
thanks
Mar 14, 2014 | Fargo HDP5000 Thermal Printer
Whats doe sthis code mean? P00701 its on my emission test saying to get it fixed
You have too many digits in there. Is it a P0070 or a P0701 fault code you have?
Jan 19, 2012 | Cars & Trucks
Hello, we are having an error pop up and I was wondering if it can be fixed here or if we will need to call in an expert and do some repairs/replacements on the device. We have a Cannon Imagerunner 5000...
this is error related to the fixing web cleaning belt. Sthis error appears after certain number of copies and means that you need to replace it.
For first aid you can clear the error in service mode. To do this on copier panel:
1) Press the user mode key ( ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( )
Choose:
COPIER>COUNTER>MISC>FIX-WEB
and
COPIER>COUNTER>DRBL-1>FX-WEB
Turn the copier off and back on.
Now you can copy/print, but call service support for fixing web replacement.
Hope that helps!
P.S.
In rare cases, E005 can occure because broken web clutch or if you do not copy in big ammount, so the web gets stuck on fixing roller and the E005 rises because the web clutch cant operate.
Aug 19, 2011 | Canon imageRUNNER 5000 Copier
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
490 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
