Where is the receiver dryer and expansion valve on a 2001 Mitsubishi Eclipse?
  • 560 Answers
Follow the smaller (high pressure) refrigerant line from the compressor to the condensor. The receiver drier will be located somewhere in between the two components.
The expansion valve will be located near the evaporator assembly along the liquid line that comes from the condensor to the evaporator
Posted on Jul 31, 2009
Where is the orifice tube on a 2002 mitsubishi montero located
Normally the expansion valve is next to the evaporator coil but if you have an expansion valve, you cant have an orifice, one or the other. To repair either will be expensive
Aug 21, 2014 | Refrigerators
2001 eclipse air conditioner please give me all problems and fixes why does not cool at higher outside temps freon is full
either the pump is only producing low pressure or the expansion valve is faulty ,you will need a special machine to sort it out as Ac systems contain dangerous gas and its an offence to let this gas into the atmosphere ,you need the machine to test the pressure and then empty the gas for work on the system and this should only be atempted by a qualified engineer
Jun 15, 2012 | 2001 Mitsubishi Eclipse
AC Problem in my mitsubishi eclipse spyder 2002 GT
Sounds like the cooling fan motor,or motors,are not working.Check the relays,and fuses for the cooling fans.If the ac is on,look to see if the cooling fan,or fans come on.If they do ,then most likely have an enternal ac system problem.The expansion valve is the most likely problem,or possible,the dryer.Have the ac system checked to see if it is low,or if the low side is going into a vacuum,if it is going into a vacuum,replace the expansion valve.First check to see if the cooling fans are working with ac on.If I can help,let me know.>>>roniecon@gmail.com
Aug 23, 2009 | 2002 Mitsubishi Eclipse Spyder
2000 mitsubishi eclipse expansion valve location
find ac lines going into firewall remove frome firewall that is where the e block is there is 2 bolts holding it to the evaporator remove those then pull it out it also helps to partially thread the nut back on the block it gives you something to pull it out with
Jul 01, 2009 | 2001 Mitsubishi Eclipse
2001 mitsubishi eclipse 3.0l ticking noise
No. The valves are hydraulic. Pour about a coke tin amount of diesl in with the engine oil. Run the enginr to normal teperature. Drain the oil and refill with new oil. It sounds like a lazy or blocked follower. Once you do this it should disappear.
May 12, 2009 | 2001 Mitsubishi Eclipse
Need to find a part on ac
the orfice tube is just as the high pressure (small line) goes into the firewall
Aug 23, 2008 | 2001 Mitsubishi Eclipse
A/C REPAIR AND IDLE PROBLEM
Clean the trottle body and air bypass valve, then disconnect the battery for 5 minutes, this should cure your concern.
Aug 18, 2008 | 2000 Mitsubishi Eclipse
Expansion valve
should be where the ac lines enter the firewall please rate -jeff
Aug 13, 2008 | 2001 Mitsubishi Eclipse
Heating & Cooling Logo
241 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
