SOURCE: Maytag Dishwasher- No water in the Tub???
after filling by hand it will go through the first cycle. every time it needs water i have to fill it by hand or it wont do anything.
SOURCE: R707 Fails diagnostic test 10 (strobe)
I found my answer to this on another board. Remove the battery and SD card. Use a paperclip to press in the small siver dot above the + sign for about 10 seconds. This resets the firmware. It worked for me, hopefully it will work for you too.
SOURCE: Roland SPD 20 shows analog test error at power on.
I am having the same issue with a SPD-11 that ahd brought from Japan. Please let me know if you get a resolution for your issue.
SOURCE: 2003 cadillac cts 3.2 liter..rough idle, scan tool
Did you ever find a solution to this? I am having the same issue on 2,4,6. I have replaced the coils. checked the intake for vacuum leaks. I am lost here let me know if you find anything and I will do the same.
SOURCE: hardware scan shows failed surface
These are problems that cannot be fixed, basically your hard drive is on the way out. Typically this is caused by drops, bumps, etc. while the machine is on.It has a SATA 2.5" 120gb 5400 RPM drive, I would suggest a larger 7200 rpm drive but it is up to you. You will also have to reinstall windows to the new hard drive.
