Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
Kenmore oven door
I've got a Sears Kenmore electric stove and the ovendoor doesn't close, the light stays on, and it loses enough heat thatwhen we use it I have to bungee cord it shut. I have tryed to adjust it but there doen't seem to be an user friendly or outside adjustment that will solve the problem, I'm am very mechanical so don't hesitate to suggest the proper fix if it involves tearing it apart. Thanx in advance
model # 790.9601 4440
serial # vf 4443 9996
  • 290 Answers
Re: kenmore oven door
There is no adjustment for the door.
If the door is not bent or warped then you need a new hinge kit. The part number is 5304445529. It includes new hinges and the recepticles that go in the cabinet. There was a service bulletin a while back about this problem and a few models were being repaired free of charge. I don't have the letter on this computer to tell you if yours falls in the free repair catagory but will try to find it and let you know.
Posted on Nov 24, 2007
0 characters
3 Points
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
What does the code PF 5A6 mean on a Kenmore range, model # 665.75132300?
got expert answers at JustAnswer Try it yourself . It's a Sears answer website. Go here and type in your question. Your question will be answered free.
Dec 15, 2014 | Kenmore Sears Electric Range Stove Oven...
Oven door
Nectar time take a photo first, they generally only go back one way.
removing the door may make it easier open the door see the hinges on the bottom lift up the little cam on each hinge then just lift the door up & it should come out.
Apr 17, 2014 | Kenmore Sears Electric Range Stove Oven...
Oven broiler will not go off., when i close oven
This is a control board issue. The contacts on the broiler relay may have welded closed. You options are to replace the controller, or disable the broiler relay output. The controller is the most expensive part of the range. The model numbers shown do not match a Kenmore stove, so I couldn't give you a better answer. Check on the back of the unit for a model number and go to Sears Parts site to find what you need. If the oven works but not the broiler you may be able to disconnect the output from the card and continue to use the rest of the range. I did this while waiting for my part to arrive. The Sears store should have a wiring diagram if you can't find the one that is usually found on the stove. Mine was in an envelope on the back of the unit, though I have seen them attached to the backside of the rear cover. Mine was just a quick connect and I pulled it loose, taped the end up and continued to use the rest of the range.
Jan 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
What causes a kenmore electric stove to flash f10
usually that is associated with a runaway temp depending on the moddle
you would need to replace the sensor
goto sears dot come typee in your model number
they will ship you the part
Sep 29, 2009 | Kenmore Kitchen Ranges
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Oven Heat
Aug 28, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
1,714 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
