Question about Kwikset Professional Door Lock installation Kit
How do i rotate the kwikset cylinder 180?
How do i rotate the kwikset lock cylinder 180 degrees?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Try this powerpoint video I made and uploaded to youtube. It is quite primitive but if you can pause and read it at each step it may help. This was for the kwikset lever entry lock. Thanks,
Posted on Sep 18, 2009
    Scholar:
  • 49 Answers
Ah, so your key is upside down when you insert it in the lock... ******** installers who don't want to take the time to install the lock correctly for the swing of the door do this alot...
Good news is that the lock works iether way, bad news is that it eventually will wear down your lock prematurely because the pins inside the lock are not meant to fight gravity and the springs get sprung!
Unfortunately to turn the keyway 180 degrees requires a special tool that comes with a kwikset rekey kit. It can be done with a flathead screwdriver but involves several steps and may render the lock useless because the final step involves bending one of the internal clips that secures the keyway to the knob... best to have it done at a locksmith and with the proper tool takes about 2 minutes and the key is not even required
Posted on Sep 09, 2009
03 Saturn vue 160 lb compression on 1/3/5 no compression on 2/4/6 timing marks are lined up.
You have 2/4/6 timing marks 180 degress out on exhaust or intake cam .
Did your special tool ?
Rotate the crankshaft using the J 42098 until the #1 cylinder is at 60 degrees before top dead center (BTDC).
Install theJ 42069 Crankshaft Locking Tool.
Rotate the crankshaft in the engine rotational direction (clockwise) using the J 42098 until the #1 cylinder is at top dead center (TDC) and tighten the lever arm to the water pump pulley flange.
Important: Ensure that the alignment of the crankshaft is not 180 degrees off. The alignment mark must align with the corresponding notches on the rear timing belt cover.
Install the 1-2 and 3-4 camshaft locks, the J42069-1 Timing Belt Alignment Kit and the J42069-2.
Important: Do not rotate the crankshaft if the camshafts are not locked in place with the 1-2 and 3-4 camshaft locks (J42069-1 and J42069-2).
Important: Do not rotate the camshafts unless the crankshaft is at 60 degrees BTDC or the valves may contact the crankshaft.
Loosen the tensioner pulley.
Remove the timing belt.
Jan 09, 2017 | Saturn Vue Cars & Trucks
How to adjust from 2 3/8 to 2 3/4? There is a pin that I can remove but don't see a bottom or how to extend... Kwikset brand Thank you... :)
If you are adjusting the backset for one of the Kwikset regular deadbolt latches, use a Phillips screwdriver to extend the bolt by turning the screw clockwise. (Hold the latch so that the word "UP" is to the top.) Then rotate the front section of the latch clockwise 180 degrees. (This is the section with the plate that screws into the side of the door.) You shouldn't need a tool to twist this section; check if you are rotating it in the correct direction.
I hope this helps. I think the procedure is the same for the drive-in latch. For that optional latch, you can't grip the plate to help you twist the backset depth adjustment.
Jul 02, 2015 | Locks & Locksmithing
Have cylinder body stuck in cradle can not remove it
If you rotate it back as much as possible toward the start position (the slot with the dot), then insert the tip of a kwikset key and give it a small twist clockwise or counter, it should be able to rotate back to start and you can remove the cylinder. I rekeyed 3 in a row no problem and had the last one jam up. I successfully restarted 3 times, but couldn't get it to complete the rekey.
Jan 28, 2014 | Kwikset Smartkey Reset Cradle 83260
Kwikset bedroom doorknob does not have exposed screws
It is very difficult thing to do it on your own and for this you need to follow the manual instructions provided in the website locksmith in san francisco or you may contact the locksmith professional as well.
Nov 14, 2013 | Kwikset Locks & Locksmithing
Can you please give me the tappet settings for a Honda civic 2004 1.6 Vtec please.
Do you mean 1.7L? I do not see a 1.6L in the manual. Instructions from autozone.com are pasted below.
lash:
Intake, 0.007-0.009 in (0.18-0.22mm).
Exhaust, 0.009-0.011 in. (0.23-0.27mm)
Civic
1.7L Engine
NOTE Adjust valves only when the cylinder head temperature is less than 100 degrees F.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. Disconnect the negative battery cable.
  2. Note the radio security code and the radio presets.
  3. Remove the ignition coil cover. Remove the ignition coils. Remove the throttle cable clamps and harness holder from the cylinder head cover.
  4. Remove the cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
  5. Remove the grommet from the upper cover and disconnect the camshaft position (CMO) sensor connector. Remove the upper cover.
  6. Set the number one piston at TDC. The UP mark on the camshaft pulley should be at the top, and the TDC marks on the pulley should line up with the top edge of the cylinder head.
  7. Using the proper gauge feeler gauge, adjust the valves on cylinder number one.
  8. Rotate the crankshaft 180 degrees counterclockwise. The UP mark on the camshaft pulley should be toward the exhaust side of the cylinder head.
  9. Using the proper gauge feeler gauge, adjust the valves on cylinder number three.
  10. Rotate the crankshaft 180 degrees counterclockwise and bring the number four piston to TDC.
  11. Using the proper gauge feeler gauge, adjust the valves on cylinder number four.
  12. Rotate the crankshaft 180 degrees counterclockwise. The UP mark on the camshaft pulley should be toward the intake side of the cylinder head.
  13. Using the proper gauge feeler gauge, adjust the valves on cylinder number two.
  14. Install the cylinder head cover.
  15. As required, reprogram the ECM/PCM engine idle characteristics. Be sure all electrical items are OFF.
  16. Start the engine. Hold the idle speed at 3000 RPM-s in park or neutral until the radiator fan comes on or the temperature reached 194 degrees.
  17. Let the engine idle for about five minutes with the throttle fully closed.
  18. If the radiator fan comes on during the five minutes, do not count this toward the five minute programming time.
  19. Set the clock.
Oct 04, 2010 | Honda Civic Cars & Trucks
How do you correct a lock that's installed up side down?
There is no real orientation to a lock, but if the key has to be inserted with the teeth up and you prefer with the teeth down, just remove the 2 screws holding the halves of the door handles on, and remove the outside one, rotate it 180 degrees, and put it back in again. It should work fine.
Aug 27, 2010 | Kwikset Professional Door Lock...
How do you reverse the handles
you mean turn the key 180? pop it out from the inside, it's held in place by a couple of spring clamps, and rotate it, then pop it back in.
Jul 14, 2009 | Kwikset Professional Door Lock...
Key is upside down, is there a way to rotate it 180 degrees without buying a "right handed" set?
on the deadbolt yo should be able to turn it over, but on the door knobs and handle sets, you are stuck with it
Jul 11, 2009 | Kwikset Brz Sgl Cyl Deadbolt
Resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
Jan 31, 2009 | Mongoose Toys
Kwikset Professional Door Lock installation Kit Logo
3,235 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
