Question about Western Digital Media Center WDXF1600JB (wdxf1600jbrnn) 160 GB Hard Drive
How do I read a hard drive taken from a WD Media
How do I read a hard drive taken from a failed WD Media Center external USB Hard Drive unit? I think the drive itself is OK but it shows up in Windows Disk Manager as 'Not Initialised'.
  • trevor_cliff Jul 31, 2009
    Sorry - my fault for being unclear! I know how to initialise the drive, but my problem is that I want to get at the data on the drive first, and initialising the drive will wipe all the data off. Trying to find out if the drive is formatted in a way that Windows doesn't recognise, and if so, how can I read it without initialising or reformatting it first.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
How to open the case on a WD Media Center - a snap!
Turn the Silver/gray case upside down.
The case should be standing in the vertical position supported on a hard surface...
-Pressing down ******* the silver cover plate with the plastic feet attached, SLIDE the cover to rear, from front to back. Off comes the bottom cover.
-Repeat for the top silver cover.
- For the silver facing cover, gently slip a flat edged tool under the rear lip of the cover plate, top and bottom. Lift gently on the silver clip edge on the rear of the facing, and press facing slightly forward until it disengages with a "click". Place a shim stock under the freed up silver clip edge to keep it disengaged, and proceed to the other rear lip. Repeat the same action, and pull facing free.
-There are three (3) compression fixtures on both top and bottom of the hard drive case enclosure. One one side, pry up edges gently with a medium flat blade screwdriver to disengage the tooth of each case clip, placing a shim stock piece of metal or screwdriver to keep case clips disengaged. Proceed to the opposite side, perform the same maneuver, watching carefully that the opposite side clips don't re-engage the case, and pop case apart.'
You now have access to the old hard drive, controller board and card reader board.
Silver tape can be pulled off gently by heating with a hair dryer, or replaced with silver metallic duct tape at Lowe's or Home Depot, usually found with the insulation materials. Mark all quick disconnect leads with labelling tape, pull out any components you wish to replace. If your hard drive is still visible in Windows, but having transfer rate problems with the controller, you can buy a new replacement Media Center model WD2500B012 on Amazon and other sites for a little less than $100.00. Simply make sure your part # matches your existing hard drive - look on the nameplate on the back of the old unit for Model and Ser #.. Swap out the old hard drive with your data, remove the new hard drive, and install the old one into the new case.
Install WD drivers available for your Media Center on the WD website BEFORE plugging in the unit for the first time to your PC
Boot your Media Center, and plug in the Media Center. Locate your hard drive and confirm data integrity. If you can see it, you can read the old hard drive. Transfer your old data. Once accomplished, reformat, and install new WD firmware if available. You can keep the old hard drive until it crashes, but I would unplug the unit, and plug in the new hard drive, format and partition, and re-run the firmware.
Re-assemble your unit in the reverse order, making sure you have all the connections and cables restored to their original position. Don't forget the three (3) copper contact feet before closing the case.
Photograph the dis-assembly to help with re-assembly.
This took me a while to figure out, nothing out there on the web, am sure others are facing this problem with their old standalone units, fretting the loss of prized images, documents. If all else fails and your drive is still visible, go to the WD website, and use their referral companies for data recovery. Good luck.
Transfer your old hard drive data into your external hard drive/PC. Keep the old hard drive (if still good), and re-install the new hard drive back into the new unit. Keep the old unit for spare parts to keep your new WD Media Center working.
Posted on Nov 27, 2011
    Problem Solver:
  • 15 Answers
Go into control panel click on administration tools storage there you can initialise and format
Posted on Jul 30, 2009
WD starts up ok, but does not recognize the external hard drive.
Check the menu, I beleive you have to tell the unit to search for an external drive. You also may have to have the drive already plugged in and running for the WD unit to see it when it does it's imput scan. I hope this helps
May 25, 2015 | Western Digital WD TV Live - Media Player...
Service center kerala
usb 2/3 external drive, i looked.
ok plug it in to all USB ports, does wondoz go ding ****?
it is on windows,right? xp/w7/w8> what?
if that fails.
try another computer. ?
this will isolate the drive to bad drive or bad computer.
Oct 01, 2013 | Western Digital WD Passport 250GB Portable...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Try a different USB cable.
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
Clicking cannot read data
your external drive has failed if its under warranty take it back to where you bought it from and get it replaced also search on youtube for videos about fixing failed hard drives i have never tried it myself but heard it is possible.
Jul 13, 2010 | Western Digital Elements powered by WD 320...
How can I turn my netork hard drive into a External hard drive
Network hard drive is also an external har drive but its shared over a network. If you want it to be used a external hard drive connected directly to you computer, read below.
Your WD drive should have a USB port on it. You need to plug the drive into your laptop directly to be used as a external hard drive.
Please rate if helpful.
Thanks
Apr 19, 2010 | Western Digital My Book Essential 1TB...
I have XP and my WD hard drive will not recognize?
Try a different "data" cable between the computer and the WD unit.
Try connecting the unit to a different computer.
If it still does not work, then either:
* the USB-to-disk-drive adapter, inside the casing, has failed,
* the disk-drive, inside the casing, has failed.
Disassemble the unit, and remove the disk-drive.
Connect the disk-drive as a "slave" disk-drive to a computer, to see if the disk-drive is OK, i.e., the USB-interface is the problem.
Copy the serial-number of the disk-drive, and use it to "check warranty status" on WD's web-site. If the drive is still under warranty, WD will replace it.
If not under warranty, WD has a "Customer Loyalty Program", i.e., buy another MyBook through their web-site, and get about a 20% discount, as a current WD customer.
Apr 08, 2010 | Western Digital My Book Essential Edition...
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
WD External Hard Drive 320GB Cyclic Error
Windows Delayed write file error
Read this
http://support.microsoft.com/kb/330174
since your talking about the External drives, a lot of reasons makes this happen. if the resolution above link cant help you, then try this:
Make sure that update the driver of your PC hard drive. Usually, this errors appear if your moving from one hard drive brand to another ex: seagate to samsung etc....
updated hard drive driver resolve this.
Make sure the cables are alright. Or at least have the latest service pack. USB drivers causes issues as well. I updated mine and the problem did not crop up anymore. hope this would help.
Feb 22, 2009 | Western Digital Elements powered by WD 320...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
PC stopped reading Cavalry External HardDrive
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Dec 02, 2007 | Western Digital Caviar WD200BB 20 GB Hard...
Western Digital Media Center WDXF1600JB (wdxf1600jbrnn) 160 GB Hard Drive Logo
140 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
