Question about Insignia D400a PC Desktop
No USB The USB ports and the flash drive readers have stopped working, The usb settings no longer come up in bios settings. This is after updating to the latest bios but long after (APPROX 2 MONTHS) Have power at the ports but no communication,
    Problem Solver:
  • 13 Answers
Re: No USB
Ok again, don't listen to these people.
I'm sorry but sounds like your flash reader died. You'll have to open the case and unplug the reader, once you did that, connect your UBS cables directly to the motherboard (instead of the reader).
Finally, about the BIOS settings, while you have the case open, theres a small metal **** in one of the corners on the motherboard (it's a three metal pins with the connector connecting to two of them. Next to it is printed something like (bios and other stuff I can't remember). Slide the metal connector off, then on the other two metal pins, then restart your computer. Your BIOS settings should appear with the USB options enabled to be modified, Save changes, and exit, a message will come up, turn off your computer, put back the metal connector over the the previous two pins, and turn on your computer.
Posted on May 13, 2008
Re: No USB
Im going to try this since im having the same problem!
Posted on Mar 09, 2008
  • 193 Answers
Re: No USB
U need to check weather teh USB drivers installed properly check this
right click on my computer-->properties-->hard ware-->device manager->and click on usb drivers-->and check weather the driver installed or upgrade the driver and reboot the pc and check rate me solved ifs its helps
Posted on Nov 24, 2007
0 characters
3 Points
Need help figuring this out. Complex!
Configuring your computer to boot from a USB drive allows you to boot into a separate operating system stored on a bootable USB drive.
This is handy when needing to troubleshoot a computer or access the hard drive without booting into the main operating system.
In order to boot from a USB drive, your computer's motherboard and BIOS must support USB booting.
If they do, then a simple tweak to the BIOS settings is all you need to do.
Shut down your computer and allow it to completely power off.
Insert your USB drive into an open USB port on your computer.
For ease of access, try to insert it into a front port if you have one.
Turn on your computer and enter the BIOS menu.
When your computer first boots, the manufacturer's logo will appear on the screen.
On the bottom of the screen is a note telling you which button to press to enter the BIOS.
Quickly press the button to enter the BIOS menu.
All manufacturers are slightly different, but some common buttons for entering the BIOS are F2, F10, F12, ESC and DEL.
If you are unsure, refer to the owner's manual that accompanied your computer.
Use the arrow keys to scroll down to the boot device menu.
It will be titled differently on different computers, but look for something like "Boot Order" or "Boot Devices."
Press the enter key to enter the boot menu.
Scroll down to "USB Drive" and set it as the first boot device.
Exit out of the BIOS menu and reboot your computer.
When your computer boots up it will boot from the USB drive first.
WeetHetBoot from USB Flash drive
May 13, 2013 | HP Compaq Presario SR1830NX PC Desktop
Usb drive stopped
Go to the device manager and uninstall the USB port drivers and restart your computer.
Here's how you can do that:
1. Right click on Computer Icon.
2. Click on Manage.
3. Click on Device Manager.
4. Go to the list and look for the USB port drivers.
5. Right click and uninstall.
6. Restart your computer.
You can also update the drivers in the computer to make it work great. You can use RadarSync to automate the updating process.
Apr 05, 2013 | Averatec AllInOne A1 Desktop (D1130ED1E1L
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP PC Desktops
The computer does not recognize flash drives and is slower than molases in January.
I've had a similar problem before and the issue could be a BIOS setting. Reboot and hit F2 or the key that gets you into the BIOS settings and check the USB settings. If legacy USB is enabled, disable it, and try again. You may have to try a couple of different settings before you get it. Good luck!
Nov 05, 2009 | E-Machines eMachines Desktop PC
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
All my computers usb ports have stopped working. when i put anything in a usb port it says usb device not recognized. i have reinstalled the drivers but still nothing works. did i fry my motherboard? but...
go threw the bios very carefully,make shure everythihng is set proper...then as a check try a usb laptop light..if it lights there is power to the ysb..if it dont..well you know it fried..if there is power try flashing the bios
Oct 09, 2009 | PC Desktops
My computer is not not recognising my card reader
update your BIOS. there might be new fix for your BIOS regarding USB...go to your manufacturers web site and download the BIOS update and install flash it to your BIOS
Mar 16, 2009 | PC Desktops
Usb 2.0 not working
you said that the usb ports are not working even if you updated the bios and chipset.what we can do is that we need to load default settings on your bios. If ever that wont work it simply means that your motherboard is having the problem. call dell tech support and they will be able to replace your motherboard if they found out that the problem is indeed your motherboard. Call us at dell. Thanks.
Sep 26, 2008 | Dell Dimension 4700 PC Desktop
Don't know whow to install my new PNY flashdrive 1GB attache'premium USB 2.0 drive
Some questions first. Does your system detect a new hardware? If yes, then do the following. If your flash drive comes with a CD, insert it then try installing( the software needed might be in there).
If your system doesnt detect your flash, then it might be that your usb port has been disabled from the Bios settings. But first check your Device Manager to see if your usb ports are working well ( From Control panel- system-Device Manager). If everything is working properly in the device Manager, then call on a technician to look at the Bios settings so as not to complicate things.
Aug 01, 2008 | PC Desktops
New Motherboard
have you check your bios configuration? if no please do.
Nov 01, 2007 | HP Pavilion Media Center TV m7330n...
Insignia D400a PC Desktop Logo
179 people viewed this question
Top Insignia PC Desktops Experts
Michael Thomas
Michael Thomas
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Are you an Insignia PC Desktop Expert? Answer questions, earn points and help others
