Car Audio & Video Logo
J
John Edwards Posted on Jan 22, 2018
Kenwood amp A-76 , can I connect microphone - Kenwood Car Audio & Video
1 Related Answer
Vladimir Frolov
  • 2075 Answers
  • Posted on Jan 22, 2018
SOURCE: Kenwood stereo integrated amp A-76, can I connect microphone ?
No, you can't. It has just line input
How to hook up kenwood equalizer GE-46, tunner KT-56, cassette deck KX56W and amplifier KA-76 with each other
Hello Pandit, the sequence of connections that I suggest, is the following, you connect the tuner KT-56 in the Tuner input of the KT-76 amplifier, the Cassettera deck in the Tape 1 connections of the KT-76, and the GE- equalizer 46 on the Tape 2 connections
I sent you the link to download the KT-76 user manual
on the third page there is a description of the connections, in your case instead of cassette 2 you will connect the GE-46 equalizer
I hope you manage to interconnect all the equipment and enjoy good music
Greetings Franco Dosil
Hola Pandit, la secuencia de conexiones que te sugiero, es la siguiente, conectas el sintonizador KT-56 en la entrada Tuner del amplificador KT-76, la Cassettera deck en las conexiones de Tape 1 del KT-76, y el ecualizador GE-46 en las conexiones de Tape 2
Te env?o el link para que descargues el manual de usuario del KT-76
en la tercer pagina hay una descripci?n de las conexiones, en tu caso en vez de la cassettera 2 conectaras el ecualizador GE-46
Espero que logres interconectar todos los equipos y disfrutes de buena m?sica
Saludos Franco Dosil
https://data2.manualslib.com/pdf3/78/7752/775116-kenwood/ka76.pdf?6a142b74fc7e4a25b8f7a8d010836b1f&take=binary
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Kenwood KA-76 amp. Left channel distorts and unit overheats then shuts down when volume is turned up. Headphones are not affected.
what happens if you reconnect left and right speakers? Are these problems of the unit or of the speakers/wires?
How do I connect bluetooth to my dnx5160
I have a kenwood dnx 5160 radio and I need to tconnect my iPhone to Bluetooth on the radio
3helpful
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
2helpful
2answers
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
3helpful
2answers
Can someone please advise me how to enter the code into my kenwood krc-585
There are free code entry instructions here (including Kenwood)
http://www.radio-code.co.uk/code-entry-help.php
Kenwood stereo intergrated amplifier a-76
The only tricks to power up again are this:
Amp to Equalizer : Use the "Connector " of the Amplifier - IN and OUT and connect them to the Line IN and Line Out of the equalizer;
All modules: Use the system control cable like in serie, for example the lowest connects to the above and from thsi one to the other above and so on;
Regarding Power: both CD, Deck and Tunner have different colors to connect to the Amplifier power source, you can't miss it;
Audio Cables, just follow the IN and OUT with correct colors and you are done!
Rgds,
TrepaTrepa
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
