Question about Jacuzzi Bellavista 6 Whirlpool w/2-Speed Motor JAC-EE20
My brand new jacuzzi bathtub motor just clicks and will not run when i push the button, whether it has water in it or not.
  • 123 Answers
Check 2 things......1) see that the power is connected and that the breaker is on.......2) if everything from 1 is a yes check the hose that runs from the switch to the motor it may be lose, disconnected or has a hole in it. If you have anymore questions just ask. I am a professional plumber for over 25 years
Posted on Jul 31, 2009
Jacuzzi tub will not turn on button will not click on as usual
Your problem is most likely NOT the air button but the switch in the motor.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Apr 10, 2014 | Jacuzzi Home
Jacuzzi majic touch won't turn on
Air Switch Repair
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
The wall electric switch for the Jacuzzi whirlpool bathtub was left on for at least one week. Have tried to push the reset button on the wall and on the motor but the pump will not turn on.
You have most likely burned up the pump. the pumps from years ago have a seal that has to have water to cool them whereas today's pump almost all of them, have a 'dry-run' seal kit so that if they are tuned on without water in them they will not burn up.
US Parts Center
Aug 15, 2011 | Jacuzzi Home
I have a jacuzzi vista 6 bathtub that all the lites come on and i here a faint noise but nothing else happens
there is an air hose that runs from the push button to the motor, it could have come loose, hopefully you have an access panel to look at the motor..
Jan 26, 2011 | Jacuzzi Home
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Nov 30, 2009 | Jacuzzi Amiga, Soaking Bathtub - 9180
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Jacuzzi tub wont power off or on by push switch to turn off or on i have to use power supply
The button is worn out. It should be a relatively inexpensive repair whether you do it yourself or have a technician drop by.
May 17, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi nova 532 motor run's but won't stay running
If it has the little oval off/on button, it sounds like the control box or off/on button is bad. If you have access to the pump assembly, follow the pump power cord to the little black box (zip tied to a tube up high), this black box has a small cable that goes to the off/on button. unplug the pump from the box and plug the pump into the power outlet. it should run continuously. If it runs, you need a new control box or /offon button. Buy the off/on button first, as this button is prone to water getting into it, and costs less than the control box.
Mar 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Bellavista 6 Whirlpool w/2-Speed Motor  JAC-EE20 Logo
366 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
