Question about Canon Cameras
Lens will not fully close.Len get stuck when retracking.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Jul 31, 2009
Canon sx120is fell while taking photos it went off with the lens retracted and it wont turn on
that is definitely the problem with the len,the len is stucked can not change freely.change the len or send to the camera repair center.
http://www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Oct 12, 2011 | Canon PowerShot SX120 IS Digital Camera
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
I have a lens error
what is the exactly error,does the len stuck and canont step back and forward. maybe your len is in bad condition or the lens bayonet is bad.
www.skiliwah.cn/
Aug 24, 2011 | Canon PowerShot SD1300 IS IXUS 105...
How do u take a len cap off the camcorders. i took the plastic one off . and it just display len cap is still on in the back grond is blue
The internal iris is stuck closed. This is not a DIY repair. If you can update this with the make and model of the camcorder, I can supply more details and a repair estimate.
Thanks,
Dan
Apr 08, 2011 | Cameras
Camera turns on but doesn't stay on. Len is fully extended can not retrack -camera does not stay on long enough. It was dropped
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 22, 2010 | Kodak EASYSHARE Z1285 Digital Camera
I have the same problem as another user who wrote: "I hardly used my camcorder. All of a sudden my camcorder can't focus, and I got a message E:61:10 on the screen." All my research on the net indicates...
for blinking E:61:10, this mean a very fine dust get inside (front of) len! must always close the len cover when NOT IN USE! to correct this, do 3 things at once, use AIR DUSTER(one use for computer blowing out particle out of the computer parts, etc.... airblow gentle in the len area at the same time as gently shaking the camcorder and zooming in/out the len! this will works most of the times.... I RECOMMEND NOT BRINGING CAMCORDER TO BEACH!!!
May 14, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Cyber-shot DSC-W150. when powering on the
allienment with the mother board and also failure of the sensors of the lens unit,so contact sony service
Mar 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
Pentex model, optio E60, get a message'"lens error:0x01110000"
after replaced with 2 fully charged battery, and pressed a few times on/off, it worked. and problem solved.
Feb 14, 2009 | Pentax Cameras
Len stuck
turn on
gently take hold of end of lense and pull and twist
you may hear a click dont pull till lense pops or to hard
switch off and on again and this should solve your problem
Jul 31, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
258 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
