Question about Sharp AR-M207E Black and White Copier
Changing a drum cartridge
I have a sharp Ar-m 207 copier machine and I wanted to know how to change the drum cartridge
  • 143 Answers
Open the right side door, open the front door, remove the toner cartridge and look inside. There should be a blue screw above the hole where the cartridge goes, loosen it and then remove the developer unit. At this point you can grab the black cover just to the right where the toner cartridge fits and pull out the drum unit.
Posted on Aug 03, 2009
My sharp AR-5316E is displaying Error F2
An F2 indicates a problem with either the toner cartridge chip that tells the machine that the correct cartridge is inserted, or the developer housing chip is defective. I would believe changing the toner cartridge will eliminate the problem.
Aug 19, 2010 | Sharp AR-5316 Advanced Digital Imager...
Toner explosion
You need to either replace the toner cartridge or empty the sump on the front of the cartridge. The waste sump is in the front of the toner cartridge, It has filled up and has nowhere else to go but out of the sump and where ever it lands. Sometimes they fill up before the toner cartridge is empty. It happens
Jul 30, 2010 | Sharp AR-207 Copier
My Sharp AR-207 gets a U2 error code. Nothing happens now. What is wrong, and how do I correct?
When your copier toner cartridge sensor is blocked.then problem arise ut or bios battery is not configure program.
reset : # - interrupt - C -interrupt press 16 press start key.
Jan 28, 2010 | Sharp AR-207 Copier
SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Jun 30, 2009 | Sharp AR-207 Copier
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
Light copies
NEVER, EVER touch the "green roller" (drum). Are copies worse than before you cleaned it. I wouldn't be surprised
Mar 13, 2009 | Sharp AR-207 Copier
I have a sharp ar 207 copier. It is giving an error code of U 2. When you press "copy" it gives a code of 40. I cannot locate the service manual. Can someone help?
you have a problem with the chip on the toner cartridge
you have to reset this via simulation 16!
if it's a refilled one have the recycler do it and replace the chip
if it's an oem ask sharp
Jan 25, 2009 | Sharp AR-207 Copier
Crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M207E Black and White Copier Logo
125 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
