Question about Dell Inspiron 6000 Notebook
Ac adaptor is internittently charging my inspiron 6000 laptop
  • 453 Answers
Try using a different wall socket. Try with a different good known adapter and check if the charging is continous. If yes then the adapter needs to be replaced else the problem is with the main board.
You can try to update the BIOS and flash the BIOS by going into F2 as soon as you turn on your laptop. Check for a n option called Restore Defaults under Maintenance. Even if this does not help kindly contact Dell for a defective motherboard.
Posted on Jul 30, 2009
  • 55 Answers
Time to buy a new. If under warranty you might be able to get a new one for free. They can be cheap on the web. Just google part number. Avoid the company, they usually charge more.
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Laptop will not charge from working adaptor
You may have damaged the dc connector on the motherboard. If the battery is not charging either then take the laptop to a repair shop and have them check the dc connector.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
May 28, 2009 | Dell Inspiron 1501 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
Battery charging status remains constant (not increasing)
I've have seen a number of different batteries do this, and I recommend what is called 're-conditioning the batteries. Do this by running the battery completely down to 0%. Then do a complete re-charge of the battery to 100% (if possible). If it charges to 100%, run it completely to 0% again and then recharge it. If it does not charge to 100%, then you may have a faulty or old battery which will need to be replaced. The AC adaptor and battery have circuitry in them and might be retaining incorrect info in them. They can be reset by unplugging them for a few minutes and then plugging them back in. There might be a specific sequence of what to unplug and when, in order to reset this circuitry. Try a couple of them. (ie. Battery, AC adaptor in to battery, AC adaptor into the wall, etc.)
Let me know what happens. Binary Bob
Nov 10, 2008 | Dell Inspiron 6000 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
