Try this...
Contact westinghouse Channel Access Service by:
web: www.westinghousedigital.com/support;
select Channel Access and enter Access info.
Text Message: Text Tuner to 95495
Phone:1-800-701-0680 follow instructions
Need Westinghouse channel code model no# CW46T9FW
Need channel code model EW24T8FW
I need channel code for model EW32S5UW
I need the Antenna [ATSC] Channel Access Code for the model CW40T8CW, Serial No. 4004V20200000 JOHN BACON (347) 812-6840
I need an acces code, model LD-3237 SERIAL NO. 6500Y14602081
Necesito un c?digo ANT 1560E1
Codes for VR - 32236 6631 H1 520 5379
O need you code acceso tv m?dem VR-4090 N?m de serie 2241168611336
I need access code model# vr-2215 serial # 6410s1900665
SOURCE: need codes to access TV menus
The solution relies with the remote. press the menu button and use the +/- buttons beside it instead of the volume or channel buttons. This TV was at a work camp in northern Alberta and the instructions were not available. Hope this helps others who do not have instructions available.
SOURCE: Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
SOURCE: i need access code for my model # ld-2240
go to www. remotecodelist.com and download for free.
God bless you
I need code for a Westinghouse tv model #CW40T2RW please thank you.
I need a channel access code for a westinghouse model EW46T4LZ
I need a access code fr a Westinghouse model EW24T8FW
I need a accesorio code for westinhouse model vr 3225
