Question about Motorola Mobility H700 Wireless Headset
How to synchronize to my phone
How to synchronize my phone motorola headset??
is it possible to synchronize this handset to a laptop??
  • 9 Answers
Re: how to synchronize to my phone
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect. This headset can sync with laptop.
Posted on Jan 30, 2008
0 characters
3 Points
I connected my S11 plantronics headset to my Cisco 7900 at work and can hear, but callers can't hear me
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Jun 03, 2011 | Plantronics S11 Headset
Motorola Service Centers in Ghaziabad
1. UCOM Technologies pvt. Ltd.
Address: B-11, RDC, 1st Floor, Raj Nagar, Gaziabad,
Ghaziabad, Opposite Reliance Web world, India,
Tel: 95120-2702852
Dec 22, 2010 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Lost the password and cannot mate a new phone/ What do I do?
Motorola handsets and accessories will use the following default passkeys: 0000 or 1234.
Thank You
Sep 06, 2010 | Motorola Mobility Bluetooth Hands-Free...
My phone is asking for a passkey to connect bluetooth.what is the passkey for the motorolla H680
For security reasons, most Bluetooth enabled devices require you to use a passkey.
Note: Motorola handsets and accessories will use the following default passkeys: 0000 or 1234.
Aug 10, 2010 | Motorola Mobility H680 - Headset -...
Unlock mobile phone (MOtorola)
We can provide remote unlocking codes for 99% of Motorola handsets cheaply and very quickly.
There is no need to send the handset to us, all we need is the IMEI (serial number) of the handset which can viewed by pressing *#06# on the handset keypad.
The cost for this is £5 or €6 and your unlock code is returned within 24 hours, although usually alot quicker, typically within 15 minutes! :-)
Drop us a mail at sales@phonezonescotland if you want more information and we will be happy to help.
Joe @ PZS
Dec 11, 2009 | Motorola Mobility H700 Wireless Headset
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
Jan 27, 2009 | Cardo scala-500 Wireless Headset
What is voice tag of H350 headset?
Voice tag is what enables you to call by speaking. So say you have a contact named Bob on your phone. You press the button and the phone beeps and you say "Bob" to call him. If you say it clearly, the phone will display Bob (and possibly any other contact that is close in name to Bob). If you don't do anything within a few seconds, it will start dialing Bob. That is the voice tag. My guess is your phone does not support voice tag or you dont have any voice tags assigned to your contacts. You will have to call from the handset, not the headset.
Dec 26, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility H700 Wireless Headset Logo
171 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
