Question about HP StorageWorks MSA20 (0808736947138) Hard Drive Array
Is 7200 rpm the max speed for the msa drives?
    President:
  • 1,335 Answers
Yes. The maximum spindle speed is 7200RPM.
Posted on Jul 30, 2009
1993 ford f250 460 5 speed rpm stuck
If you are talking about the meter located in your dash, if you are able to, pull your dash meter assembly out and just bump the needle downward. It may have simply gotten stuck at it's highest point. If this does not correct the issue, you will either need to replace the meter and/or look for a short in the wire that feeds the signal to the meter itself. A shorted out wire will give a signal to the meter that it is maxed out and therefore reads as though engine is turning at max rpms all the time.
Aug 16, 2013 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
Do all external hard drives described as "superspeed" have a spindle speed of 7200 rpm?
No... It refers to the fact that they can run faster because they are USB 3.0 compatible.
Jun 28, 2012 | Computers & Internet
Hard drive capacity
It's 10.2 GB
Maxtor 10.2 GB UDMA/66 7200 RPM IDE Hard Drive
General Features:
10.2 GB formatted capacity
UDMA/66
7200 RPM spindle speed
2 MB buffer
9.0 ms average access time
4.17 ms average latency
E-IDE/ATAPI interface
3.5-inch form factor
Notes:
Drive only
Maxtor model #: 51024U2
Additional Information:
Product Requirements
IDE controller
IDE cable
Available 3.5-inch drive bay
Available 4-pin power connector
Jun 28, 2012 | Maxtor Computers & Internet
Code da620000 what is capacity
It's 10.2 GB
General Features:
UDMA/66
2 MB buffer
Notes:
Drive only
Product Requirements...
IDE controller
IDE cable
I have a Sony vaio vgn-cr120e laptop,the factory harddrive has 140 GB 5400 rpm,I want to buy an external harddrive that has 7200 rpm,I would like to know if the 7200 rpm going to be compatible with my PC.
For and external USB drive, the RPM is of no consequence. Internally it should only help speed up the access time, assuming it is the same type of drive.
Hope that helps.
Apr 02, 2011 | Sony Computers & Internet
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
I am trying to find out the speed RPM of an external hard drive
You dont have to worry because it is advance hard disk for 250GB USB 2.0 Desktop Hard Drive
7200rpm already
Regards
Balisonu79
Feb 13, 2008 | Iomega 33089 250 GB Hard Drive
HP StorageWorks MSA20 (0808736947138) Hard Drive Array Logo
118 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
