Question about Zanussi FJ1454W Front Load Washer
Door locking when i start a load the door lock does not alway lock. at time's it lock frist time, then at time it you can hear the lock but the door is does not locking and the light also does not come on the door.
  • 139 Answers
This could be a fualty door inter lock.. easily repalaced...
Posted on Dec 02, 2007
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error dl f: door will not lock to start wash
This is obviously a door lock/switch assembly failure. The fault code FdL flashes if the door locking routine fails, after six attempts, to lock the door. You should hear the door lock clicks six times before the fault code flashes. Replacing the door lock/switch assembly is the only viable solution and it's a do-it-yourself repair. You only need a pair of needle-nose pliers to stretch the door gasket retaining hoop and a Phillips-head screwdriver to remove the screws securing the door lock/switch assembly to the front panel. Click on the link below for the detailed instructions on how to replace the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 17, 2011 | Kenmore HE3T Washer
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer
Door lock error replace the door lock switch
May 16, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
My 96 stratus power door lock only lock and unlocks the drivers door. what could the cause be?
poss u have a bad power door acclulatiors do u hear the power door locks on the other side? or poss bad fuse check fuses frist
Apr 09, 2010 | 1996 Dodge Stratus
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer has an F dl problem?
Fdl is a code that indicates a door lock error. The clicking sound that you hear is most likely the door lock. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Zanussi FJ1454W Front Load Washer Logo
66 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
