Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
What do i do
Put on a wash in washing machine and disturbed the cycle by switching the knob to spin and since then every time i put on a wash the cycle knob just keeps on going around by its self. I have carried out what it says in the manual and that is not helping it also said in the manual that if the knob constantly goes around then i need assistants, can u please tell me what to do.
Thank You.
  • 69 Answers
Try manually moving the knob through each cycle until it gets back to the finished cycle. or the timer may need to be replaced
Posted on Jul 30, 2009
How do I fix a top loading washing machine that isn't spinning, agitating or draining?
if this is a top loader put a pencil into the lid switch opening if the machine spins and drains when the timer knob says it should the tab on the lid or the lid switch has failed...replace the switch or the tab that goes into the lid switch opening
Jan 26, 2016 | Amana Washing Machines
Kenmore washing machine doesn't always spin.
I guess when it spins OK. When it doesn't spin, can you just turn the knob a little to put into spin cycle, or can you wiggle the knob up down side to side and possibly engage spin cycle? If so the switch is not making proper contact. You can continue to operate in the above manner or you can have the switch replaced. The switch could cost quite a bit along with labor and the machine may not be worth it. Your choice of which way you want to go. GOOD LUCK FRIEND.
Nov 28, 2014 | Kenmore Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
When our washer is done with the wash cycle, it doesn't drain the water out and so when it's on the spin cycle, the knob just ticks through it. What could be the problem for the water not draining out, a...
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 06, 2011 | General Electric Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Will Wash, but not discharge water nor spin.
the lid switch is broken PLEASE rate my help!! Thankx
Oct 03, 2007 | Whirlpool LXR5432KQ Top Load Washer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
291 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
