Question about Car Audio & Video
Unit will not except cd , radio work's fine, but when you push button to open front to install cd every thing is good to this point.when i place cd in slot it will not except cd, it does display loading, but that's it. there is no disc in player , then unit will return back to radio ??? note this is installed on motorcycle, marine type. i have also pushed reset button, problem still exsists
  • 3,267 Answers
It seems something is preventing the disc to spin hence its rejecting it. It has to with the CD player's mechanical system where mostly plastic gears are being used. These when worn out can lead to such problems.........sodeep
Posted on Jul 30, 2009
Ca900 radio wont work - the radio lights up as expected but the main area that normally displays what station yo are listening to is blank. No sound comes out except from the beeps when pressing buttons on...
Hello Dan, have you tried to reset the unit using the reset button behind the front panel? also try to clean the panel metal contacts, clean them using a cotton swabs or an handkerchief wet with alcohol, both side (main unit & detachable panel)
Oct 23, 2013 | Car Audio & Video
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
My Pioneer DEH-P3500 car stereo is having problems. The front panel buttons will not work at all... the radio was working, but the head unit would not let me change stations or make any adjustments. I...
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
Jun 21, 2011 | Pioneer DEH-P3500 CD Player
I cant eject my cd
There is a indent in the front of the face of the radio. Try to push it with a sharp pencil or pen. It might reset the cd part and eject button might work again. If not you may have a cd stuck in it then you can try get tweezers and pull it out or a credit card and try to straighten it out. Those were some of the techniques I used when I was an installer for 12 yrs.
Apr 07, 2010 | Sony CDX-M630 CD Player
I am unable to open the Panel to insert cd
somtimes you have to disconnect power to the unit. pull the unit out and unplug it or disconnect the battery. if it doesnt work you may need a hammer.
Mar 06, 2009 | JVC KW-AVX800 CD Player
Buttons not working except for Volume
hi you may have a button jammed, or dirty contacts on the connector try giving them a clean. if not you may have a crack in the pcb. its common for people to drop, sit on etc.. there front panels.
www.carradiospares.co.uk
Nov 24, 2008 | Pioneer DEH-P5500MP CD Player
No display
Did you install the unit with the correct wiring harness, or cut-and-splice the wires from the factory line to the stereo lines? This could be a problem.
Aug 27, 2008 | Car Audio & Video
JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Aug 11, 2008 | JBL - MR4W Am/Fm with CD Player White
Freak Out!!!
Correct on the ribbon cable but parts can be ordered for it, duel has service centers, inc the one i work @. its abought a $10 part
Oct 07, 2007 | Dual XD-7500 CD Player
NO Power
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key one. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Sep 03, 2007 | Dual XD-7500 CD Player
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
