Question about Nintendo Wii Console
Wii system is showing no power but I unplugged and tried rebooting but alas no power still HElp
    Problem Solver:
  • 6 Answers
You should take it apart and look at the power pak
Posted on Jul 30, 2009
Fixya com
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
Perform an AC Adapter Reset. To perform an AC Adapter Reset follow these instructions: Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  1. The AC adapter must remain unplugged at both ends for a full two minutes.
  2. Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  3. Check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If the AC Adapter shows signs of physical damage and needs to be replaced, a replacement can be purchased from Nintendo's online store.
  4. After waiting two minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then the AC Adapter reset was successful.
If these suggestions don't work try visiting Nintendo's help pages at: http://www.nintendo.com/consumer/systems/wii/en_na/ts_system.jsp
Apr 21, 2013 | Nintendo Wii Console
Wii no longer turns on! no power??
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  1. Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  1. Check the AC Adapter for the following:
  1. After waiting two minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then the AC Adapter reset was successful.
Aug 16, 2012 | Nintendo Wii Console
Hand cursor wont show up on tv when i use nyko wand for wii
Got you my friend. Unplug the console for about 10 minutes then plug back in. That reboots the system
Dec 14, 2017 | Nyko Wand? for Nintendo Wii
After working just two days ago. The console will not power on. It has not been moved. We have unpluged everything,no luck.
Hello
Start simple. If there's no power to your Wii, check that the AC adaptor is firmly connected both to the game console and a live electrical outlet. If you still have no power, or the power LED light goes off in midgame or flickers, try rebooting the system. Turn everything off, unplug the AC adaptor from the electrical outlet, wait at least 60 seconds and then plug in again and turn the system on.
If this does not help you may need a new power supply.Also try cleaning the wii.Use a can of ampressed air to blow out any dirt or dust from unit.Pay attention to fan area.Be sure fan spins free.
Sep 23, 2011 | Nintendo Wii Console
My wii system doesn't detect my virgin mobile mifi 2200. i tried entering everything manually but alas no luck. im using my mifi right now to be on here and using it with my 360 but my wii is being a baby...
there are series of problem in nintendo wii which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the nintendo repair guide that will help you a lot...
click here to download repair guide
Dec 28, 2010 | Nintendo Wii Console
Wii console power light is not on. The console is plugged in.
Try the following (this was taken from Nintendo's website and the following link
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
  • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
  • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Also, see if you have a friend that has a Wii, and try their power cord on your unit. You may have a faulty cord.
Good luck.
Jan 19, 2010 | Nintendo Wii Console
Made a loud noise and then wouldn't turn on t.v.
you need to reset the configuration and it also happens when the systems been on for a long time unplug the main power supply for 30 mins and try again. hope this helps and also try and clean the disk and let them dry.
Dec 31, 2009 | Nintendo Wii Console
When i turn the wii on a screen appears and it says to press A to continue but nothing happens when you press A.
unplug ur wii and wait about 1 minute then plug it back in. The wii is a computer and all computers will crash and you will need to reboot them
Oct 10, 2009 | Nintendo Wii Console
My wii after trying to run homebrew channel doesnt have power
You probably just need to reset your Wii's power cable. This happened to a lot of people I know.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Aug 14, 2009 | Nintendo Wii Console
My Wii is TURNED ON but not showing on the screen!!
Dude, you must have broken something inside of it. Phone nintendo.
May 17, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
61 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
