Aiwa Stereo System NSX-F9
This system holds up to 5 CDs at a time but has developed a fault in the disk-change. What happens is this:
I load the CDs, close the drawer and press the button (ie 1-5) of the selected record.
The disk 'platform' rotates and stops at the disk but then immediately rotates again back to the same disk, stops again and nothing else happens except that sometimes the display shows 'CD' instead of the disk number.
I've had the system for several years so it may be that parts are no longer available but I would appreciate your advice.
Many thanks
Bert Bareham
  • Meldrew Nov 28, 2007
    I purchased a lens cleaner CD but it made no difference.
    The problem seems to be that as the system won't play normal audio CDs it won't play the lens cleaner CD either so it has no effect.
    I'm wondering now whether it is a dirty lens causing this failure or could it be something else which is causing the CD trays to continue to rotate, eg worn mechanism?
  • Meldrew Dec 12, 2007
    As I mentioned in my original posting of 24 November John, I open the disc tray, load 5 CDs then press the number of the first one I want to play. The drawer closes, the CDs rotate, (there are a couple of 'clicks' between each disc movement), and when the selected disc arrives at the playing point rotation pauses for a few seconds then begins again. The selected disc reaches the playing point for the second time, another pause with a few clicks, but instead of the track numbers panel lighting up to indicate that play is about to start the letters CD appear in the screen and every button locks up.
    Very very rarely a disc will play correctly so I wonder whether it's more likely to be the ribbon cable that's faulty rather than the laser or lens?
    Would appreciate your further guidance John.
    Many thanks
    Many thanks
  • 26 Answers
This could be a number of things, the lens could need professional cleaning ie dismantling and cleaning the lens.
The lazer could be faulty or more likely, the disc loading mech ribbon cable could be faulty.
Does the disc actually load or does it just pause then continue?
John w
Posted on Dec 12, 2007
  • John Wright Dec 13, 2007
    On this particular CD mech the Laser unit retracts with the disc before reading the TOC.
    The lens focuses the laser and when focus lock is achieved the motor spins.
    If the cd is located as described I would suspect either a dirty lens or a faulty laser.
Insert CD lens cleaner first, then try to load audio CD if do not work change the lens
Posted on Nov 25, 2007
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
Aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
Dec 06, 2009 | Aiwa Audio Players & Recorders
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
741 people viewed this question
