Question about Thetford Porta Potti
Depress flush can hear motor trying to work but nothing happens
  • 20 Answers
You will have to take this apart and check if there is a foreign body stopping the blade from turning.
Posted on Jul 31, 2009
2005 cavalier regulator not functioning to lower front driver side window. window is in up position. cannot hear motor engaging to lower window when switch is depressed/activated. sounds activated to...
If the motor and regulator both work fine or sound like they are engaging when your try to raise the window,but you hear nothing when you try to lower the window then I think it is a pretty safe bet to say your switch is bad.
Sep 17, 2011 | 2005 Chevrolet Cavalier
The wipers will not work - I can hear the motor when switched on but no movement. Replaced fuse still doesn't work. ??
if you can hear the motor trying to work and nothing is happening that means either the motor arms are in a bind or the motor is locked up
Sep 14, 2011 | 1993 Dodge Dakota
Control panel works. i am able to change all selections or settings. When I depress the start button i hear an audible click but nothing happens. No errors are showing on panel.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2010 | Dryers
My drivers power window won't work. suddenly quit..depress the window and nothing happens, don't hear anything..all other windows work..need new motor? can i do it myself and save over 300 that the repair...
before you change the window motor check to see if you are getting power to the motor frist it could just need a new window
switch but if you need to change the motor the only thing you need to get the rivets out is a drill and a drill bet and they will come out
Aug 17, 2010 | 1999 Chevrolet Suburban
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Trigger safety lock
If safety button won't depress, something is blocking operation inside the handle. If button actually depresses, but nothing happens when power switch is operated, then a bad switch, motor brushes worn or stuck, or internal wiring is broken at some point due to vibration. If it is still under warranty, take advantage of it. Does chain move freely by hand and has proper oiling? Can you hear any humming inside when power switch is depressed? Could be frozen motor bearing or damaged drive assembly. In any case, the housing will need to be removed for further inspection if you are going to do the work on this.
Apr 25, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Ice maker makes ice, but won't dispense.
if you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Dec 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Thetford Porta Potti  Logo
101 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
stynger007
Level 1 Expert
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
