Question about Acer Computers & Internet
I have an Acer Aspire 5515 laptop. When Im typing the lers sometimes dont show up. Ihav to hit the letter key a couple times for it to work sometimes. any suggestions on how i can fix it?
  • 499 Answers
First of all u need to remove ur power plug and the battery
then pull a little Aciton around each button which stuck
use any cool air dryer and direct it through these buttons which u have put an Aciton on it
keep ur cool dryer ( not hot air cool air plz) about 5 min. directed to the buttons
leave it about 30 min
if this not work then try this
u need to clean ur keyboard cause it seems that ur key is stuck so u need to dissassemble ur keyboard and clean the carbon points in ur keyboard (after u dissassemble it) using Aciton and tishue
otherwise u need to change ur keyboard
Posted on Jul 30, 2009
Acer aspire 5515 laptop is not booting and I'm unable to reinstall the OS
If that is the case, remove HDD and test. Replace if necessary.
Nov 18, 2012 | Acer Aspire 5515-5187 Notebook
If i pressed letter the show is number.how can i fix it?
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Sep 28, 2012 | Acer Aspire One D257 Netbook
When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
Hi
Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
Or try this
If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
Try the following steps in case your laptop keyboard displays wrong characters:
1.Go to the control panel option
Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
4.Click ?
'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
This should solve your problem
Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
Aspire 5515 touchpad not working
It might be a keyboard shortcut you unintentionally pressed. On an Acer 5515 it
May 19, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5515 erecovery manager does not work. i can see three options restore from factory or user disc or exit the only one i can choose is exit
try restarting your machine. tap the correct key to get into your bios. most of the time its f2. in there make sure the recovery mode is active/enabled. i believe on an acer its called D2D. then when you restart your machine hold down shift key and tap f8, that should take you through the recovery. let me know if that helps
Good Luck!
Ruben
Jul 15, 2009 | Acer Aspire 5315 Notebook
My acer laptop keyboard isn't working!
my acer 5515 laptop keyboard wont work
Jul 02, 2009 | Computers & Internet
Keypad needs replaced and I need to find the correct one
If you need to purchase one Amazon has it: http://www.amazon.com/s/?ie=UTF8&keywords=aspire+keyboard&tag=googhydr-20&index=aps&hvadid=3451242089&ref=pd_sl_cxsfg05xc_b
But I'm going to assume you need instructions on how to replace the keyboard.
A very good guide for the 5100 model can be found here: http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
I've noticed that most Acer Aspire keyboards are removed in a similar fashion.
Good Luck!
Jun 01, 2009 | Acer Computers & Internet
Computers & Internet Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
