Question about Nokia 6300 Cellular Phone
Can i have to check the life timer or talk time.number.if i want buy new phone can u suggest the best phone . range is between 6000 to 7000.wat u say about 6300
  • 9 Answers
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
Posted on Jul 30, 2009
@will_56: There's no PUK for Phone, but SIM card puk! You should check with SIM manufacturer.
@gr_vineeth: You should recharge to increase battery life. As long as you keep the sim card on and use it, it's going to use some voltage!!!
Posted on Jul 13, 2012
Need to get new login for different cell that's on straight talk to purchase more mins.
you can buy minutes at walmart then add using your phone or the refile option on there site then just add phone number and number on the card or call straight talk use debit/credit card to buy minutes that way using the automated system
Dec 15, 2014 | Straight Talk LG L40G Cell Phone
Tip
Nokia codes +++++++
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
on Sep 05, 2009 | Nokia 6300 Cellular Phone
Batteries are going down one phone at a time. Is it cost effective to buy new batteries?
Most cell phones have relatively cheap batteries these days. For example, my current phone's battery only costs about $30; my previous phone's battery only costed $15. If you're experiencing worse than usual battery life on your phone, it's completely worth it to buy a new battery. I suggest looking on an online store (such as Amazon.com) for batteries rather than buying directly from the manufacturer due to the lower cost.
Smartphones generally have slightly more expensive batteries, but it's still worth it, in my opinion, because you'll always be sure you're getting the full life out of your phone.
Jun 01, 2011 | Cell Phones
My brinks 44-1020 digital timer was set up right and dose not work. i bought a new one and that one also dont work am i doing something wrong or is there a lil trick to it
1) I posted Brinks 44-1020 manual
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
Folks can order Brinks manuals from hamptonproducts.com
2) Manual shows phone number for defects 800-562-5625
3) I test timers, and some arrive defective, and people occasionally tell fixya they got 3 bad timers in a row. I tell them buy different model: for example buy quality timers at Lowes and Home Depot
4) Timer manuals have more words than allowed for free answer, but I suggest you write out steps shown in manual. Most timers have same basic steps so once you know how one timer works, all other timers work same way. This will eliminate human error as possible cause.
5) Here is a list of common problems with timers:
If plug-in timer doesn't work
a) Check receptacle for power
b) Check lamp is turned ON
c) Check bulb is good.
d) Check tabs or pins are set
e) Check override switch pushed fully in position
f) Try timer in different plug and with different lamp
g) Test circuit with inexpensive circuit analyzer from hardware
h) Don't exceed maximum wattage
i) Programmable: check for overlapping programs, and conflicting days.
j) Programmable: write out programming steps
k) Outdoor with photo cell > test with black tape over photo eye
l) Turn photo eye away from light source
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Hampton Technologies Brinks Timer
Need to reset the life timer of my nokia 6233
You probably cannot reset the lifetime timer on this or any telephone. I don't know where you are located, in my case, that lifetime time number is put onto my telephone by my service provider and covers all the time I have used since my account was started, including all the telephones I have had associated with my number. Someone else may have a different idea that would be appropriate for your handset in your location. If it is a big concern for you, I suggest you contact your service provider directly.
Thanks for your interest in FixYa.com
Jan 27, 2011 | Cell Phones
Timer wheel seems to slip. Won't hold time
You posted under Intermatic T104 timer.
If you have different timer, information below may not fit your timer.
Add a comment with correct timer brand and model number.
1) Click manual override on-off to see if Load turns ON, and that override snaps crisp and clean and is not sluggish or hard to move.
If override is not functioning well, then timer is bad. Buy new timer.
2) If dial is rotating, note current time, and watch if dial is keeping correct time over full day.
If dial is running slow, then buy T100 series 240Volt clock motor for T104 timer.
3) If dial is keeping good time, then tripper might be worn and need replacement
Link below shows Intermatic T100 series parts:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
4) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
Jan 06, 2011 | Intermatic T104 24h 208-277v Mechanical...
I forget my nokia 6300 lock code
Hey dude,
Let me tell you all the lock code for Nokia cell :-
Any network this is for (NOKIA phones only),
i hope its more than enough :)
Nov 15, 2008 | Nokia 6300 Cellular Phone
Forget the security code of my cell phone
Hey,
here is the list for all lock codes for nokia :-
I hope it wld wrk like magic :)
Nov 15, 2008 | Nokia 2100 Cellular Phone
Nokia 6300 Cellular Phone Logo
248 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
