SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
SOURCE: dryer keeps stopping - check filter light on
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
SOURCE: TV goes off after 20 seconds Samsung HLS5086wx
First Take off the Lamp Door and replace it back the way it was secured with all of the screws. Doing this will reset the safety interlock switch which heats up and opens the circuit causing the set to shut down. After doing this and the set still shuts down check the lamp. Depending on the amount of hours on the lamp it may be a bad lamp. They will fail with out any obvious signs. If the set shut down and goes straight to the Stand By condition then you have a bad Power Supply. If you hear a whining or buzzing sound then you have a bad Color Wheel.
SOURCE: we just purchased a new Samsung Dryer model
Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
Hello friend, thanks for your post!
I understand that your Frigidaire dryer is beeping and flashing lights. To reset your dryer you should disconnect power, by unplugging it or flipping the household circuit breaker, for roughly ten minutes. Which lights are blinking on your display panel? It could be providing you an error code.
If the reset does not help correct the issue, could you please provide me with your model number? Typically you can locate the serial tag (which lists your model number) on the door frame of your dryer. If you need further assistance please reconnect with me. -Matt
