Question about Maytag Dryers
Making a loud squeal when the dryer is running. Its not continuous and the clothes still dry. Its a stacked washer dryer combination neptune series machine.
    President:
  • 704 Answers
This is a fairly common problem with the Neptune dryers. There are two (2) roller wheels at the front and rear of the dryer drum and a felt gasket that runs all the way around the front edge of the front of the cabinet that the drum edge sits on as it rotates around.
As these wheels and felt wears (they seem to wear more quickly for some heavy users), the metal lip of the drum will start to rub and wear on the metal lip of the cabinet. Those roller wheels at the rear and front of the dryer drum can also be the souce of this type of noise, but since you're going to have to remove the drum to gain access to the felt or the wheels, I find it best to replace ALL the wheels and the felt at the same time while I have the unit apart, since it's only a matter of time before the other wheels and/or the felt wear out and start singing their own lovely screeching song.
As always, the cost of repairs needs to be weighed against the age and condition of the machine and the cost for a new replacement appliance. My rule of thumb is when the repair costs exceed 60% of a brand new unit AND the age of the appliance is 10+ years - time to buy new. Otherwise, get an estimate or the cost of the repair parts and make the repair yourself.
The cost of this repair by a appliance tech can run around $250-300+ depending on how long this has been allowed to operate, as the drum and cabinet can get worn pretty badly over an extended period of time with this condition not being corrected.
It is a repair that a homeowner can undertake given you have some experience, patience and are willing to take the 2+/- hours it will require to get it done. Not to mention having obtained the replacement parts you need to get the repair accomplished. Hope that helps!
Posted on Jul 30, 2009
No heat for my frigidare fex831cs top load stacked washer dryer
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Feb 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
My washer makes a loud squealing noise when it spins, what is wrong
Hello Kathy McAlister - Typically, when the washer is making or produces a squealing sound is due to an overloaded load. I recommend running a cycle with less clothing. If issue continues, then consult with a professional to accurately pinpoint any potentially more serious issue like a faulty belt or a bearing/pulley suspension problem. The washer could possibly have broken something off in between the tub and outer portion of the unit.
Feb 23, 2013 | Frigidaire FEX831CS Top Load Stacked...
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Loud noise on spin cycle only clothes dry good
Sounds like your bearings and seal need replaced... See Neptune Bearing for information on the Maytag Neptune bearing and 12002022 seal kit. You can also rent a special tool kit that includes the bearings, 12002022 seal kit, bearing spacer, step by step DVD, etc.
I would not run neptune with bad bearings too prevent more damage to the Neptune spinner support, Motor drive system...
I hope this helps you...
Feb 01, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
135 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
