Question about Samsung ML-3561N Laser Printer
Engine Fuser Low Heat Error
Was working fine and then the following message appeared with an orange light "Engine Fuser Low Heat Error"
    Problem Solver:
  • 19 Answers
The fuser is responsible for heating up and transferring the toner to the page. Possibly the low temperature light is telling you that it is about to fail (it is a replaceable part) or warning you that this could be the cause of print quality not being what it normally was.
Posted on Jul 30, 2009
  • Samsung Master
  • 1,684 Answers
You need to replace the fuser in the printer, the part number is JC96-03406A You can do a google search for the best price.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
2 Suggested Answers
  • 525 Answers
SOURCE: Was working fine and then the following message
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
'Engine Fuser low Heat Error' is showing, where and what is the fuser?
The fuser is a cylinder usually covered with a non-stick (Teflon-like, usually black) surface. Inside, it has a light bulb that heats the fuser's surface to a predefinde temperature. During the printing process, the drum (also a cylinder, usually with a metallic color) lays the toner on the paper sheet, then the fuser is rolling over the paper and is melting the toner so it is fixed on the paper.
The message means that the temperature read by the temperature sensor is too low, so the printer will not be able to melt the toner.
This may be caused by the following problems:
a) the bulb (lamp) inside the fuser is burned;
b) the power supply of the fuser is defective;
c) the temperature sensor is covered with toner residues.
If you do have some intermediate technical skills you can:
- for a): replace the fuser lamp
- for b): consult the service manual and repair the power supply
- for c): locate the temperature sensor (it's like a metallic pill, about 1.5 cm - 1/2 inch diameter and has 2 pins or contacts), carefully lift it from the fuser drum then wash it with white spirit. Be careful not to spill the spirit inside the printer and not to touch the other parts, especially the forosensitive drum.
You can tell if your problem is c) if you power on the printer, wait for the message to appear, then open your printer's covers and locate the fuser. If it's hot, then tfe problem is c). If it's not, the problem is a) or b).
Jul 21, 2011 | Office Equipment & Supplies
Nov 01, 2010 | Samsung ML-3561N Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
Error Engine Fuser low heat
possibly the fusers thermostat is displaced. it rides very close to the roller to get an accurate reading, look for 2 wires into a black "thing" toward the middle of the roller. this is a thermistor which sends its reading to the mainboard. check if the fuser is getting very warm, there is a thermo couple in series with the fusers power so it wont overheat but if its getting hot and the printer doesnt know it then the dammaged/displaced thermostat would be the thing to look for,
Sep 28, 2009 | Samsung CLP-600N Laser Printer
ther is a prob in your fusing unit, chances are the thermistor is not working, if you can still feel some heat in this area, either the lamps are working fine but the sensing device fails to read the actual temp.
you need a tech to correct this prob
Jul 27, 2008 | Samsung CLP-510 Laser Printer
How do I fix an Engine Fuser Low heat error on printer:
UNPLUG AND REMOVE 5 SCREWS ON THE FUSER HOUSEING . CK WITH METER TO THERMOFUSE
Nov 05, 2007 | Samsung CLP-550N Laser Printer
THERMO FUSE OR THERMISTOR DIRTY OR BAD
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Aug 28, 2007 | Samsung CLP-510 Laser Printer
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung ML-3561N Laser Printer Logo
588 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
