Question about Cameras
Just opened a dxg538. i noticed when i turn the power off it does not come back on until i take out the 2 AAA batteries and put them back. according to the user manual when you replace worn out batteries the camera retains the date/time for three minutes but no matter how quickly i replace the AAA batteries i lose the time/date settings. can i replace the memory battery?
  • crsn_wllm Jul 30, 2009
    is this something that can be done practically or would i be better off trying to find a computer repairman since i don't want to go through the problem of shipping it back to the company
    President:
  • 2,777 Answers
Hello there, that battery can definitely be replaced. However it is something that the manufacturer usually has to do. I am having a hard time locating the type of battery used internally, but please give DXG a call and they will tell you if it's possible for you to replace it or that is something you would have to do. They will also have the battery type information. Their number is (626) 581-3742
Posted on Jul 30, 2009
  • 3,037 Answers
Yes you can replace the internal battery, it is just a pain to do so and many times just not worth doing especially not if you are going to pay someone else to do it. You need to unscrew the screws holding the front and back of the camera together to gain access. I would advise against it as you can easily then disconnect something but that is where the battery will be located and a new one can be picked up at Radio Shack if you wish to replace it. Let me know how this turns out.
Benjamin
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 05, 2016 | Taylor Measuring Tools & Sensors
I brought a remote and put in 2 AAA batterys and it was small
what was small, the remote you brought or the 2 AAA Batteries? if the 2 AAA batteries are small try the medium size batteries. GOOD LUCK!!!!
Oct 05, 2011 | Televison & Video
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
AAA said battery was dead and starter was bad, it would only click once until the battery was completly dead. Put a new battery in and had interior lights, etc. Tried to turn it over, and only one click...
iwould check positive and negative power at battery end and at starter and engine block end
also check power at any distribution block (points) for corrosion or partially brocken connection
or loose at mounting points
Apr 06, 2011 | 2000 Honda Accord
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
Cant get Y values when i type in X values in table
Well first of all you can try to reset your calculator, just follow the below steps to know how to reset it -
1. Turn off your TI-83 Plus.
2. Open the battery panel on the back of the calculator and remove one of the AAA batteries. Keep this battery handy, as you'll need it again.
3. Press the "Clear" button, and keep it held down.
4. Put the battery back in and turn on the calculator, with the "Clear" button still held down. When the calculator's screen displays the message "RAM Cleared," release the "Clear" button.
5. Remove one of the calculator's batteries again. This time, hold down the "Del" key.
6. Reinsert the battery and turn on the calculator. Release the "Del" key when the screen reads "Waiting...Please install calculator software now."
7. Use the TI Connectivity cable to connect your calculator to your computer. Run the TI Connect software to reinstall the calculator's operating system. If you don't have an up-to-date copy of TI Connect, see Resources.
8. Turn off the calculator and disconnect the TI Connectivity cable. Remove the AAA batteries, as well as the small, circular lithium battery.
9. Wait five minutes before putting the batteries back in. Turn on your calculator.
Hope it helps ..........
Good Luck!!
Thanks
Jan 06, 2010 | Texas Instruments TI-83 Plus Calculator
I turn on the calculator and it comes up with the little black thing in the left hand corner. Then it turns off. It doesn't allow you to do anything, it just shuts off. At first I thought there was a...
Your calculator may need to be reset. Open the battery door. There's an internal battery behind a little door with a screw right above the 4 AAA batteries. Take this battery out. Leave it out for about 8 hours then put it and the AAA batteries back in. Hopefully this will solve your problem.
Jul 10, 2009 | Texas Instruments TI-84 Plus Calculator
TI-84 will not trun on.
Try the following
1) Remove one of the AAA batteries, hold down on the DEL key while reinserting the AAA battery. The handheld might display Waiting…Please install calculator software now. Ignore this message. Remove and reinstall one of the AAA batteries again This time, do not hold down the DEL key.
2) Remove one of the AAA batteries, press and hold the [on] key for 10 seconds, release, replace the battery, then turn the unit on. Adjust the contrast.
3) Remove the AAA batteries for three hours. After the three-hour period, reinsert the batteries and turn the handheld on. Adjust the contrast if necessary.
If needed, reinstall OS by downloading the OS from the TI site and ....
On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
(I am not the one who came up with this answer, but found it on an other site. If this doesn't work, please let me know)
Gr Marijn
Nov 28, 2007 | Texas Instruments TI-84 Plus Calculator
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
