Question about Sewing Machines
Needle hits bobbin plate - Sewing Machines
  • 26 Answers
Out of time, keithat11@aol.com i can repair if you want to ship to me
Posted on Aug 06, 2009
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate.
Aug 13, 2015 | Singer Pixie Plus Sewing Machine
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
I have a bernina activa 130 and when you turn the wheel to insert the needle into the fabric the needle breaks. I am not sure what to check.
Check that your needle is centred when straight-stitch is selected and / or that you have the correct stitch-plate fitted. Is the needle breaking because it is hitting the stitch-plate or is it breaking when the needle goes down through the slot/hole in the stitch-plate. If you are sewing zig/zag or patterns, you must have a slotted stitch-plate fitted. If it's breaking when the needle passes below the stitch-plate, then take the bobbin /bobbin case out and the hook/shuttle and see if it still happens. If it does, the timing on your machine may be out and need professional adjustment. If it doesn'y happen after removing just the bobbin case, make sure the bobbin case is being correctly fitted.
Sep 19, 2011 | Bernina Activa 130
My needle keeps hitting the plate and breaking. How do I fix this?
Take the needle plate off and see where it needle is connecting with the bobbin. The bobbin case may not be in place and this is what the needle is hitting.
Feb 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
My DB2-B797 suddenly has needle breaking because needle is hitting bobbin. I need help with technical specs and needle positioning. PLEASE
Hi
First thing to check is are you using the correct needle, if it is too long this will hit the bobbin holder.
If the needle is the correct one, for some reason your timing is out or the needle bar has dropped lower than it should be.
I can't explain on here how to re-time as it is complicated.
If the timing is out it is very unusual as the working parts are locked in position.
Take out the thread, remove the needle plate and turn the machine over by hand watching the needle and see if it is actually hitting the bobbin or bobbin holder.
Rob
Jan 02, 2010 | Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Needle hits the plate
Remove your needle plate, clean around it, turn the handwheel to see if the hook will catch your thread(Like you are trying to bring up the bobbin thread). If it catches okay, put the plate back on and as you tighten the screw push the plate towards the rear of the machine. Reassemble everything, rethread , insert a bobbin and try it by turning the handwheel again. If it still hits, you need a service. If it doesn't, have fun!!
ssewman7
Jun 07, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
185 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
