Question about Euro-Pro Shark GI490 Iron
I am getting a dark blue-gray residue coming from the steam holes! I've tried to clean it by pressing the 'self-clean' button but the residue continues.
  • 154 Answers
Use vinegar to clean
Posted on Aug 02, 2009
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
While steaming clothing, a white flaky residue is being left on the clothing. Sole plate is clean. Residue seems to be coming from steam vents. What do I do to continue using this great iron? Evelyn Roll
Are you in a hard water or soft water area, maybe you could try using filtered water in your iron. To clear out the scale from the jets try adding a little white vinegar to the water and steaming it through, or a little "Calgon" diluted in water. Then perform a test iron on some dark fabric untill the scale has been removed.
Aug 02, 2010 | Rowenta DX6700 Iron
I need to descale my iron Do I just fill and dial self clean?
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 16, 2009 | Irons
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
The iron has plenty of water in the reseviour but will not steam. I have press the steam button and steam comes out but it will not steam otherwise
Your iron may be due for a cleaning. After awhile the ports inside the iron become clogged with mineral deposits.
Try using a mix of 1/2 white vinegar and 1/2 water. place the mix in the reservoir and allow the iron to heat up for steam until the reservoir is empty. Then do a second round with plain distilled water. Clean the the iron plate of residue after it cools.
If the vinegar mix does not work (and you can do the mix a few times) try using a product such as "Lime Away" or "CLR" to dissolve the deposits. Hope this helps.
Jul 12, 2009 | Irons
Solenoids workin, steam lines fine, but no steam
take hose off from iron end,press iron button ,breifly! keep tight hold of hose [best to put towel around hose while holding]see if steam comes out.if not hose could be blocked, then take hose from solenoid end and press button .if no steam comes out the solenoid is either faulty or the valve hole inside is blocked,turn off power and take nut off top of solenoid ,check spring and plunger for condition.the small hole may be blocked in the solenoid housing,try a needle in the hole to clear any blockage.
Jun 24, 2009 | Irons
MY iron is less than 1 year old. It has been stored for about 3 months. Now when I tried to steam a garment with it, it does not steam unless I hold the steam button down. Otherwise nothing comes through...
Sounds like there was water in the line when it was stored, which caused deposits to bild up in the line and not work without pressure. Hence having to press the button to get steam out.
Try loading it full with really hot water and a small amount of bleach. Steam all of the water out of it into the air. Clean out the resevoir with fresh water after it has cooled and try again.
Please remember to rate this solution.
Feb 19, 2009 | Rowenta Professional DX8900 Iron
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
139 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
