Question about Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless B BEFW11S4 ver.4 installation drivers.
I got the above wireless router with power supply and connecting cables. However I do not have the CD.
How do I find the CD information and drivers for the router.
Deepak Vora
deepakrvora@yahoo.com
  • 54 Answers
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a linksys befw11s4 router, i dont have a install disk, the router works, i just need to set up and secure my network, how do i do that?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or "1234" blank.
Then you can see configuration page of router.
If you are not able to access router then RESET it .You can RESET it with reset button it is in back side of router press it for 10 seconds then all settings goes to defaults then you can access it with above link.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 16, 2010 | Linksys BEFW11S4 802.11b Wireless...
My Linksys BEFW11S4 Wireless-B Broadband Router? i cant connect in my internet and my PSP how can i do to connect it?
Set up an open wireless network or with WPA encryption. The PSP supports WEP/WPA but not WPA2 or Wireless G, it's a B device.
Also use a short passphrase and DHCP to lease IP Addresses.
Nov 03, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
What are the default router numbers for linksys Wireless-G WRT54G router, or does everybody have different numbers.
What numbers are you refering too? Of it is the IP address most manufacurers use 192.168.0.1 or 192.168.1.1 I believe linksys uses 192.168.1.1
Jun 16, 2009 | Linksys Wireless-G WRT54G Router
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Again
Did you get my other reply?... about disabling you wireless care and har wiring your computer to YOUR linksys? I posted it this afternoon.
Mar 11, 2008 | Linksys BEFW11S4 802.11b Wireless...
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Need driver
Routers don't actually have drivers. Linksys provides some software that can make the installation a bit easier, but no driver is required (or exists).
The Linksys website has some good instructions on installing and setting up their products. I would begin there or if you can give me more details on what problem you're having I would be happy to help.
Dec 22, 2007 | Linksys Wireless Ap + 4 Port Router...
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G Range Expander (WRE54G) Logo
2,071 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
