Question about Samsung RESF3330D Electric Kitchen Range
Oven heats 75 degrees cooler than the specified setting
And a crackling noise is sometimes heard which comes from behind the range. Anyone with similar problems.
  • 867 Answers
Some kind of wiring/control issue, although it may be the thermostat in the oven making the noise and needs to be replaced
Posted on Jul 30, 2009
Glow bar lights up, but oven does not heat up all the way to desire temperature.
You oven sensor is what detects the temp and relays it back to the control.
Here it is: $75 bucks for the exactamundo
You can buy an oven sensor on ebay way cheaper. Replacement is easy.
Sometimes if the connection is corroded you can bypass it and it will magically work some more.
Just check it for 1100 ohms at 75 degrees and make sure ether wire is not grounded .
If the connected looks contaminated cut it out and bypass it. That might be all it takes.
The new part will come needing to be spliced in.
If the sensor is fine then the oven control is what will need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
The oven doesn't come close to keeping a REASONABLE temperature. It fluctuates sometimes 75-100 degrees. I'm not talking about opening the door and then waiting to re-establish the temperature it was set...
If you just bought it, have it replaced, or repaired under warranty. If it is an old oven, replace the temp probe first (if it electric) It senses the temp inside oven, It is the least expensive part of the fix. If that doesn't work, replace thermostat/temp control board. When you replace a board, you replace the probe too. It will be needed either way. If just changing the probe works, you saved yourself some money.
Apr 06, 2010 | Kitchen Ranges
Oven not heating properly
Hello- Sometimes ignitors work enough to light burner, but not enough to step up gas flow at regulator. Lower burner ignitor is bad if resistance is less than 4ohms. New part through local app. parts store.- 50-75$. Ignitor is mounted next to burner under bottom pan in oven. Plug is behind pan drawer. Fairly easy to replace. hope this helps- Thanks- ED
Feb 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Jun 24, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
May 21, 2009 | Kitchen Ranges
Ge stove
Replace the temperature sensor inside the oven cavity. It looks like a small metal rod. Be aware you will never get an accurate temperature reading with those cheap 5 dollar things. After the oven is preheated, you must wait 10 minutes and take a reading. Some models have a temperature adjustment, it's listed in the owners manual.
Oct 28, 2008 | GE JBP69 Electric Kitchen Range
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Samsung RESF3330D Electric Kitchen Range Logo
204 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
