Question about Dell Inspiron 6400 Notebook
Message on screen: configuring updates: stage 3 of 3 - 0% complete. Then computer restarts. over and over and over
  • Dell Master
  • 1,606 Answers
First we need to break out of the cycle. Try booting into safe mode using the f8 key on startup. Usually press power and start tapping the button or it will miss it. Let it boot completley and then open my computer and see if you have any space left on your C drive. If you do then shutdown and reboot into normal windows. If not empty recycle bin and run start-all programs-accesories-system tool- disk cleanup then reboot into normal windows.
Going into safe mode should get you out of the cycle at which point you want to manually run the windows update from either the start menu or from internet explorer tools. That will download new versions of the updates and install them.
If it is still in that cycle then you might need some local help as the update files need to be deleted. These are found in the windows directory so you have to be careful not to delete the wrong files. If you ran the disk cleanup that should have deleted these files and made enough room if not then I would need to know exact update names and so on to be able to help you with this step.
Posted on Jul 30, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: configuring updates
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
bye
Posted on Jul 31, 2008
XPS M1330 laptop is stuck at update 3 of 3. It is in a loop between the update and restart.
Search Results
Latest Vista Update stuck in Stage 3/restart loop - Microsoft ...
https://answers.microsoft.com/...update/...update-stuck...3restart-loop/2f70b13c-9db4-...
Jul 26, 2009 - I have Vista Business system on a Toshiba notebook, latest Service Pack and with allupdates. ... I just booted it up to find the Stage 3 page of a Windows update. ... Have tried using F8 to get last good installation, and to stop auto restart, without success, it just keeps returning to ..
Mar 21, 2017 | Dell XPS M1330 Notebook
My computer is stuck in the configuring updates: stage 3 of 3 - 0% complete.
give it some time to install that update, if its still not working then might be possible that the update was not downloaded properly or it got corrupted while installation due to which its stucked on stage 3 of 3.
In these situations we can try to restart the computer into the safe mode and and then check which update is causing the computer to stuck on stage 3 of 3. If possible try to kill that update in safe mode too. To help you on that you need to provide me some more information.
Which operating system are you using?
Feb 13, 2011 | eMachines T3616 Desktop PC
I have an Ace Aspire 5810tz laptop; windows vista. While it was running an update, I was tired and shut it off during the 3 0f 3 configutration. Now that is all it does. After startup, it goes to a blue...
Hi follis_valpn,
If you are trying to install the Windows Update 937287, you will get this (configuring updates stage 3 of 3. 0% complete) message. If you are getting the message even after restarting the Computer, you may need to repair the Windows (using the installation Disc) or restore the Computer to an earlier date.
First you can try restarting the Computer in the Safe Mode and do the System Restore. To access the Safe Mode, please press and hold the F8 Key whlie restarting the Computer. Then, please click "Start", "All Programs", "Accessories", "System Tools" and "System Restore". Then, please select a restore point (Date) when the Computer was working correctly. This should restore the Computer to the selected date and fix the issue.
The, alternative option is to use the Windows Installation Disc and perform the "Repair" option.
The issue will be fixed after you perform any of the above steps. To avoid the issue in future (whlie doing the Windows Update), please download and install the Windows Update 937287 from Microsoft Download Center separately.
Below is the link to obtain the Update.
http://download.microsoft.com/download/3/b/d/3bd7db67-7a7a-4c16-b10a-e0eace7d9473/Windows6.0-KB937287-v2-x86.msu
Hope this helps..
Good Luck!
Thanks for using Fixya.
Oct 01, 2010 | Computers & Internet
My hp laptop dosn't move in configuring 3 of 3 - 0%complete,and then it just switch of and on,and comes back to configuring 3 of 3 k 0% complete
Vista Update Stage 3 Stall……
You see Installing Updates Stage 3 of 3... 0% in Vista after you start or restart your computer and it never goes past 0%. Rebooting the computer doesn't change it. It still boots to Installing Windows updates 3 of 3 and never goes past that 0% mark. Sometimes Windows will even reboot in some cases. I have found that this often happens after Windows updates. I have no idea why, but this seems to be a fairly common occurrence. The last one I repaired was caused by a Service pack 1 installation.
Here's what I have done to fix the 3 of 3 error.
You will be doing a System Restore from the Vista f8 startup
Since the computer your working on is probably stuck on this screen the first step will be a hard shut down.
Hold the power button down until the computer shuts down.
Restart the computer.
Tap the f8 key about once or twice per second to get the Safe mode screen to come up.
In Windows Vista there is a new choice when the safe mode selection comes up. "Repair Your Computer"
Highlight the "Repair Your Computer" choice.
Windows will act like it is going t boot up.
You will see a System Recovery Options window.
It will ask you to choose your language.
Click Next
Select your user and put in your password. (leave blank if you don't have a password)
You should now have choices and the one you want is "System Restore"
Follow through the prompts with the Vista System Restore program.
Remember you should pick a restore point that is 1 or 2 points back.
Once you have completed the system restore process you will be asked to restart your computer. Go ahead and restart the computer. It should start correctly at this point. If you don't have a restore point available you may not be able to repair this error. I have not tried to repair one of these without a restore point yet.
Aug 12, 2010 | HP Computers & Internet
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
Apr 03, 2010 | Dell Inspiron 1525 Notebook
When I turn on my computer the screen reads configuring updates: Stage 3 of 3 0% complete. Do not turn off your computer. Then it goes to shutting down. It starts up with acer, microsoft corporation the...
downloads are either being stopped by a firewall or your system cannot update what it needs to because your missing other updates. if you dont have all required updates some others will not install.try automatic updates.download all critical and recommended updates.
Oct 05, 2009 | Acer Aspire 9410 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
Configuring updates
bye
Jul 30, 2008 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
242 people viewed this question
Alun Cox
