Question about Orion STV2763 27" TV
The cable jack on the back of the tv has broken off. We went to hook up the cable and when we went to twist it on it came off onto the wire. We have only had the TV for 3-4 years. Is there warranty? If not what can be done?
  • 26 Answers
The cable fitting was attached to the tuner, any tv shop can repair the tuner and put a new fitting on. I usually handle this type of repair for 45 to 55 dollars.
Posted on Sep 18, 2009
I have a cablevision box with a set of red, green and blue wires and another set of red and white wires. How do I hook the cable to tv to get cable? The colors on the front and back of the Mickey tv are...
hi. The colored cord you described are for high definition, there should also be some jacks on the back of the cablevision box that say "video out" "left""right"
Find those, and the video out is the yellow in jack on Mickey, and the Left is the white jack on Mickey
If you can't find those, then use the cable tv out from the box to hook it up to your tv.
This is all that is needed to hook up really, just the coax cable from the box to Mickey.
I know Mickey has a antenna cable jack on the back.
Just run a cable from the box to mickey, put Mickey on channel 3, or 4, depending on what the setting is on the box, and you should be good to go!
Feb 08, 2011 | Disney DT1300-C 13" TV
The box on the back of tv that the coax cable turns onto is broken. Can we go buy a cable peice and just solder it back on or do we need to order the whole little box?
You can buy the RF jack and solder it back onto the tuner as long as the tuner has not been damaged beyond repair. Inside the tuner the center conductor from the jack solders into the printed circuit board. If any small parts are broken or missing then you will have to replace the tuner.
Jan 04, 2011 | Sony KP-41T35 41" Rear Projection...
DELL SPEAKER SYSTEM STOPPED WORKING
Suggest you abandon the mini-phone jack connection - sounds like a wire is broken in that connector. Use the RCA stereo outputs from your TV into the Dell surround system. You may need a couple of adapter cables to make that work. Take photos of the connectors on the back of your TV and on the back of the Dell Surround system. Take those to an electronics store like Best Buy and ask for help there to get the cables you need (telling them that the mini-phone (headphone) plug is giving you trouble.
Apr 22, 2017 | Dell 5650 Computer Speakers
How do you hook it up to a vcr ?
there are a few ways , depending on the model and depending on what you want to hook it up to. basic rule is.... output to input. find the audio and video out on the gadget you wish to hook up. then find audio and video in on tv or whatever you hook it up to.... some devices have a few different kinds of jacks on them. rca jacks are the red, white, yellow ended cables.... or you can just use a coax cable.... thats the thicker cable with a little metal wire sticking out the end that screws onto the only thing that it'll screw onto. or theres s-video.... which is also pretty unique because you can only plug it into one thing, but you'll also need to run the rca audio cables ( the red and white ended things) if you use that. so... to clarify... output to input... all ya gotta do is read the back of your gadget and you should be able to figure it out. hope that helped.
Oct 12, 2009 | Apex Digital HT-150 System
How can I still use this TV?
find another TV, VCR (many around now), or other cable using device and exchange - 7 or so screws on  back of tv come right off and expose lower interface where cable jack is.  remove wires, solder salvaged unit in and it works....  Be careful when removing back of tv -  you can pull other wires when doing so.
Mar 11, 2009 | Sharp 27L-S100 27" TV
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Orion STV2763 27" TV Logo
127 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
