Question about Acer Aspire E500 PC Desktop
Computer keeps crashing on startup
When the computer turns on it will start to load everything and before i can start to do anything it will crash and the blue screen pops up saying windows is shutting down to prevent damage to your computer and it has driver_not_equal_or_less if this is your first time youve seen this stop error screen restart your computer. if this screen appears again follow these steps:
Check to make sure any new hardware or software is correctly installed if that doesnt help disable or remove any new hardware of software...
tech information:
*** STOP : 0x000000D1 (0x00000014, 0x00000002, 0x00000000, 0x8C0A7F7C)
*** ndusuio.sys - Address 8CoA7F7C base at 8CoA50000, DateStamp 4549b2f2
It will allow me to do safe mode with networking and that will stay on for about an hour and then that also crashes and comes up with the same screen. I have tried to do a reboot to last known good configuration and it had the same result. There is a program that I know is probably a virus its called Personal Antivirus. I have tried to remove it but my computer wont stay on long enough to do so. Will that one program cause my computer to keep crashing? Or is something else causing it?
    President:
  • 1,884 Answers
Whatever the reason, it seems that WINDOWS has crashed or is about to. I would recommend a re-install. Your data would be safe but you will have to re-install other progs. Alternatively, if you can take a backup of your data (not the progs) thenformat the disk while installing Windows. Do you have a partition on the HDD? If no, then partitin the disk and keep C: only for Windows. This way you are safer comparatively whe undergoing a viral attack.
Posted on Jul 30, 2009
  • 129 Answers
Some thing wrong with your ram or hard disk.format hard disk using dos.you cannot use dos which is given in winxp use win 98 bootcd.
then install windows hope it work.if this not solve problem check ram,pci cards,or chanage hhd.when something wrong with your hardware or motherboard this type of error come.first i prefer do steps which given above then open your back of pc.
    President:
  • 1,335 Answers
If you can run in safe mode and access the internet, there is a way to remove the Personal Antivirus malware. It is involved and too long to list here, but go to
www.2-spyware.com/remove-personal-antivirus.html
You may still have other virus problems if Personal Antivirus malware has been on your system for some time
If you cannot run in safe mode or cannot access the internet, I would reformat your HDD, reload Windows and reload your applications to make sure that you have a clean system. Also, you should make a system backup so that you can restore the system should you have problems at a later date.
The solution is not simple.
  • 433 Answers
That blue screen you see is the ever dreaded Blue Screen Of Death or BSOD for short. Most of the time it's a hardware issue. Could be a hard drive or memory failing, or it's a cpu or motherboard issue. Check processor to see temperature in bios.
Unplug all devices...cd rom...graphics cards, etc. Just have memory and hard drive connected. See what happens. If BSOD still, then put memory in another slot, just use one stick, or try a new stick See if you can try another hard drive to narrow it down to a HD or cpu or mb issue.
Good luck,
Hank
Windows 7 crash on windows is loading when i boot
If you can boot to safe mode, but do not get anything on the screen, try pressing CTRL+SHIFT+ESC to bring up task manager. See if anything is running. If you don't have anything, it could be that you need to start explorer.exe. You may need to pull your hard drive, backup your files and reload the OS.
Oct 16, 2013 | Microsoft Windows 7 Professional for PC
When i turn on the computer the windows xp load screen comes up as always but this time it keeps freezing so i cant get into my computer
Try to boot in safe mode and check wether its entering in the windows, if its work then choose privious restore point & restore your pc. also remove any unwated software, keep the HDD free from excessive fragmentation, as this may help prevent startup problems, freezeups, crashes etc.
Jul 20, 2010 | Computers & Internet
My computer keeps turning its self off before it gets to the desk top screen.
i think your operating system is crashed or corrupted. try to boot in safe mode. for boot in safe mode press f8 at the time of startup and select safe mode. if your system boots in safe mode. If its a crash of operating system then run chkdsk for c drive and select two options with tick marks. it asks to scan at next time startup. select yes and restart your system. after scan it will fixed.
Jun 16, 2010 | E-Machines eMachines Desktop PC
Plugged in the 1TB WD My Book Essential into my Dell Dimension 3100 running windows xp and the screen goes blue and I get a error stating "Bad_Pool_Header"
here's a solution I found on google:
BSOD the Solution:
Did you install Service Pack 2? Are you now suffering from the Blue Screen of Death (BSOD)?. Here is the solution. I have spent 4 days hunting down the cause of my machine crashing and have finally cracked it. Maybe other people have a different cause than mine so my solution may not work for everyone.
After installing SP2 I suffered many crashes. In particular the Screen would turn blue and display a message starting "Bad_Pool_Header". And ending with STOP: 0X000000019....
Then my four day hunt for the cause started.
BSOD Solution
Basically I found two causes of the BSOD.
Cause 1: Corrupted file or folder.
Cause 2: Microsoft Indexing Service
Possibly these two causes are linked.
Solution for Cause 1
Onen up Explore (right click the start button), and expand your directory tree, starting from the C: drive. Click on each folder in turn and see if any cause the BSOD to appear. If so, reboot, and simply attempt to copy the folder, and then delete it.
Solution for Cause No 2
Switch off Microsoft's indexing service. You can do this by clicking the start button, select "Run", then type "msconfig", then select the "Services" TAB, scroll down to the Indexing Service and Switch it off. Reboot your computer, and good luck - maybe it will work, It solved the problem for me.
At first I thought I must have a third party software or hardware conflicting with SP2, but even after I had disconnected the internet, switched off all items in the startup TAB of msconfig, was still getting the BSOD. I tried surface scans, chkdsk, scan disk etc all to no avail. I tried defragmenting the disk, but the frequent crashes may have made things worse.
I discovered the computer was now crashing after about 7.5 minutes of being switched on. It did not matter whether anyone logged in or not.
Finally I went to msconfig (Start Run, MSCONFIG) and switched off "process System.ini files, Load System files, Load Startup Items. And the comuter stopped crashing. So then I added the item back one by one until I discovered the Microsoft Corporation Indexing Service which was causing the crash. I switched it off and switched everything else back on and AT LAST... No more BSOD
Jan 01, 2010 | Western Digital My Book Essential 1TB...
Tiger Woods 08 used to work fine.. crashed, now it won't load.
u might have to turn the computer off then put it in again...if it still dont work, then call a representative from EA games.
Aug 28, 2009 | EA Sports Tiger Woods PGA Tour 07 for...
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
Beeps alot, while it take a while to load the page, and the video card stops working, it crashes sometimes have to reboot everything
problem: Overheating
Solution: Attach small fan over heatsink on video card also recommend rear case fan..Keep it Cool
Apr 16, 2009 | Computers & Internet
Slow computer
You have to many programs running on startup, and one of the when it gets around to starting is causing your pc to crash, you can click start,all programs,accessories, then Run. Type msconfig,click on the startup tab and uncheck everything, you can rechck them one or two at a time if you dont know what they are, then restar and see what happens. you will have to enter safe mode to do this since your PC crashes. to get to safe mode turn on your PC and start tapping on the F8 key you will see a Microsoft menu, choose safe mode, and follow prompts to get to the desktop, then do the above. if you have 2 PC's, you can go to pacs-portal.com (google it) to find out what each item in the startup tab in MSCONFIG is and if you need it or not or if its a virus. Or Restore your PC to factory settings
Mar 29, 2009 | Computers & Internet
My computer keeps crashing
have you got enough ram need at lease 1 gig of ram
Aug 23, 2008 | Computers & Internet
Computer crash no sound
check the printed circuit board, check for cut lines
Dec 14, 2007 | HP Compaq FS 7550 17" CRT Monitor
Acer Aspire E500 PC Desktop Logo
207 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
