SOURCE: Dyna-glo parts
skypainter, I also am having the exact problem you are. After reading what buffalo said, I removed my glass cover and knocked the pilot piece a couple of times with my screwdriver handle and so far so good. Guess it loosened up the spring. Just hope to get through the cold season.
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
SOURCE: dyna glo torpedo heater has e 1 error code and shuts down
you either have too much air pressure or you don't have enough pressure.do you know what your pressure is set at.
