SOURCE: wurlitzer 2500 jukebox
You don't give enough information. Is it in the play position? Is it putting the tone arm down on the record?
SOURCE: My jukebox doesn't play
DOCTOR-FIXCAN MAKE A COPY FROM MY ORIGINAL. MOST LIKELY YOUR PROBLEM IS THE LIGHT THAT COUNTS AS EACH CD PASSES. LOOK BETWEEN CD CAROUSEL, AND CD GRIPPER ARM. A CD MAY HAVE HIT THE METAL LEAVER THAT THE LAMP,
IS ATTACHED TO. YOU HAVE TO GET DOWN 0N IT WITH A MIRROR TO SEE THE LAMP, AND SEE IF THE METAL LEAVER IS NOT BENT. FOR COPY OF WURLITZER MANUAL, A CD RECORD PROBABLY HIT THE LAMP. 636 2273300. NAME IS SEYMOUR LEVITT COMPANY NAME IN-HOME JUKEBOX REPAIR. [email protected] THIS IS A COMMON REPAIR PROBLEM. GOOD LUCK.
SOURCE: need manual for Wurlitzer jukebox 1015 45
I suggest that you check out the Victory Glass wedbsite for a manual.
www.victoryglass.com
Regards
Alan Hood
ami-man
UK
SOURCE: Jukebox CD Player: wurlitzer 1015 cd player take about 5 minutes befo...
Faulty CD player or faulty control pcb under the laser unit. That's assuming it is not spinning at all until ages after it has put the Cd down.
