Question about Saeco Vienna De Luxe Espresso Machine
Our machine is turned on but the green light is not flashing
  • 2,039 Answers
Inside the machine from circuit board to pump check if the wire not disconnect and check the inside fuses
Posted on Jul 31, 2009
Just the power light comes on
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Dec 02, 2012 | Zanussi FJS1225W Front Load Washer
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Hope this helped.
May 18, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
HP 2550 will not print. Green light flashes. I'm
If the machine is making "working noises" while it flashes, it is most likely calibrating. A good way to find out if the problem is due to connectivity issues with your computer is to turn the machine off, unplug for 1 minute, plug back in and turn on. Wait until the light is solid, indicating its ready to go, and then press and hold the green button until the lights flash. It should produce a demo print for you. If it doesnt, the problem may be with the printer, not the computer. Also, check in the "Printers and Faxes" settings in the control panel (if you are running windows) to see that the 2550 is set as the default printer.
Feb 20, 2009 | HP LaserJet 2550n Printer
Philips magic 5 primo machine doesn't send or receive
the green flashing light means your ink cartridge is empty
you need to replace this before you can send/receive
once you have installed new ink green light will go out
Jan 12, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Saeco Vienna De Luxe Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
