Question about Brother IntelliFAX 2800 Laser Fax
Not receiving...see tad on screen i can send - Brother IntelliFAX 2800 Laser Fax
  • 215 Answers
Press the "receive mode" button on the front panel until you see either "auto" or "fax only".
good luck,
razors
Posted on Jul 30, 2009
I can't receive a fax i can send one but cant receive
Hi there!
You can try checking on these steps to resolve your issue:
1. Make sure that you have the normal screen on the LCD ex. date/time FAX (Receive modes can be TAD, MANUAL, FAX/TEL) Please take note of the display.
2. Just to double check press Hook to verify if you have a dial tone.
3. Make sure you have the correct Receive mode on your screen
4. To change the Receive mode to the correct receive mode just press Menu 0,1 then press the arrow keys to select the correct Receive Mode press OK to choose your selection & press the STOP/EXIT key to go back to the main screen.
Hope this helps!
Rate if it works
Thanks!
Mar 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
Does not receive what does TAD mean on the LED display? WIll not send
TAD means telephone answering device. if you are running a dedicated line to fax, you will want to switch that to "auto" or "fax only".
good luck,
razors
Jan 10, 2011 | Brother IntelliFax-2820 Laser Fax
TAD error
Change the RECEIVE MODE to FAX ONLY. TAD stands for telephone answering device which is used if one of this device is attached the EXT port.
Dec 08, 2009 | Brother IntelliFAX 560 Plain Paper Fax
FAX MACHINE NOT RECEIVED FAX I CAN SEND BUT
you need to change your mode key to fax only
Oct 26, 2009 | Brother Office Equipment & Supplies
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Problem receiving faxes
your fax is in tad mode (telephone answering device) press the receive button (next to the start button) until you see fax only on the display this will correct the problem.if you have faxes in memory press the report key for reports, then opt.1 for help list
look for print fax
Jul 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Receive faxes
In the receive mode choose tad. The fax will then distinguish between a fax and a call.
Feb 16, 2008 | Brother FAX-575 Plain Paper Thermal
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
90 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
