Question about Proscan 19LA20Q LCD TV
It was working fine, then I went to turn it on and the light stays red, and the screen doesn't work. It sounds like it's trying to come one though.
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Kodak z650 comes on fine but doesn't stay on-funny noise before it cuts off
Hello Donna, You camera is suffering from age, needs to be repaired or time to replace it. Sorry.
Nov 02, 2012 | Kodak EasyShare Z650 Digital Camera
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
No video or sound
Hello.
Most likely this is an output problem. But I have had 1 PS3 that had a bad hard drive and it wouldn't even load to the XMB. So try another hard drive and see if that works. Even a swift smack to the old one may work. If that doesn't work try the video out reset.
Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
Hope this helps. Good luck!
Aug 19, 2008 | Sony Playstation 3 (PS3) Console
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
Jun 11, 2008 | Nintendo Wii Console
N64 Console
try using the cables instead of RFS's
Apr 01, 2008 | Nintendo 64 Console
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
Working fine next day red light on solid
Shorted hori output transistor and bad 1200pf 2k volt capacitor.
Sep 15, 2007 | Sony KP-53V80 53" Rear Projection...
Proscan 19LA20Q LCD TV Logo
168 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
