Question about LG 42PX5D 42 in. Plasma HDTV
Lg42px52 speckling. I own the above tv, & the picture uality is very poor. The speckling of green red & blue spots all over the screen makes the HD effect pointless. I also have boarder burn when pictures are only shown in 4:3 have left there mark. Any advice. It's nearly 2 years old.
  • 87 Answers
The speckling is caused by the CTRL board. The firmware needs to be updated. Unfortunately LG does not provide a media slot for downloaded upgrades. You must order an install the factory updated CTRL board located between the power and the Y sustain boards.
Posted on Nov 25, 2007
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but...
the red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Colorful "speckles" on screen
Could be the screen burn from watching T.V. on a show and the thing burnt in (in this case the colors, yes it can burn colors.) and there's nothing you can do. The insides of the T.V.'s have plasma gases which can flow out of control.
Jan 14, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I get a red/blue/green static at the top of my plasma tv.. when the picture goes to a dark color its usually speckles red.. then when its a light color it doesnt really show.. wats the problem?
In some cases it is just a matter of making voltage adjustments on a plasma set to get rid of the spots you are seeing. I would look for a reputable technician in your area to see if this is the case. Good luck...
Nov 18, 2008 | Televison & Video
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
3 green spots on the top center of my projection hd tv
I had a similar problem and brought it in to a technician for a quote of $860 to fix. The problem - speck of dust on the optics. If it weren't under warranty I would take it apart and blow off the dust myself.
Dec 19, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Quasar SP-3233 TV
well it's not a wide screen tv show it won't really matter but if it is H/D you will find a red/green/blue connection in the back for picture and red/white for sound
Aug 10, 2007 | Quasar SP-3233 TV
Toshiba 43H70 HD Projection TV
this is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
May 23, 2007 | Toshiba 43H70 43" Rear Projection...
LG 42PX5D 42 in. Plasma HDTV Logo
280 people viewed this question
Computer Repairing
Computer Repairing
