-All burners or just one or two....?
-If all burners then gas pressure might be down due to On Off valve on the main pipe might turn 1/4 or more to closed position.
Make sure all On Off valve must turn to full open.
-But if only 1 or 2 burner do that then:
-Turn off gas valve to the stove before process.
-Remove all the cover and the inside orifice and soak it in warm water with soap.
-Use Only nylon brush or tooth brush to clean.
-Let air dry only. Do not wipe or dry it with towel or toilet paper.
-Never use metal or brass brush to clean.
-Never drill or enlarge the hole.
Put it back and try how it works.
Good luck
Mai
Thank you, Mai, but it is the oven burner, not the hob. All the hob burners are fine, so not gas flow. I believe it is the thermopile, which was knocked in the cooking accident.
-If it's the oven then pretty much some of the holes are clogged or rusty. If you can clean then clean until the holes are visible. If not then just buy a replacement burner. Thank you Mai Lor
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
If you hear clicking or sparking, go to Step 2.
If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
Check to see if the burner works, If not, then go to Step 3.
Check to see if the burner works, If not, then go to Step 4.
SOURCE: low flame and not heating oven
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
SOURCE: gas cooktop - burner won't ignite
if its the burner that hase the intermitent timer on it
i have the same problem & I troubleshooted it.
if u take the cover off thier is a part on it that the rest dont have. its a red thing that rotates & thier are little contacts in it. for some reason thier is something that messed up inside it.
i took both mine apart & switced the guts & one of the little "boards"
is not working properly.
so im shure that is your problem
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
