Hello Ron,
If you have already replaced the thermostat unit and both heating elements, and the indicator light is coming on and the fans are running, but the oven is still not heating up, here are some additional troubleshooting steps you could try:
Check the wiring connections: Ensure that all wiring connections are secure and properly connected. Loose or faulty connections can prevent the oven from heating up.
Check the oven control board: The control board regulates the power to the oven elements. If it is faulty, it may prevent the elements from heating up. You can test the control board using a multimeter or by having it professionally checked and repaired or replaced.
Check the thermal fuse: Some ovens have a thermal fuse that protects the oven from overheating. If the thermal fuse has blown, it can prevent the oven from heating up. You can test the thermal fuse with a multimeter and replace it if necessary.
Check the temperature sensor: The temperature sensor is responsible for monitoring the temperature inside the oven. If it is faulty, it may prevent the oven from heating up. You can test the temperature sensor with a multimeter and replace it if necessary.
If none of these steps resolves the issue, it may be best to contact a professional repair service or the manufacturer for further assistance.
If your Roper oven is not heating, there are several possible causes. Here are some steps you can take to troubleshoot the issue:
Check the power supply: Make sure the oven is properly plugged in and that the circuit breaker hasn't tripped. If the oven is getting power but still not heating, move on to the next step.
Check the heating element: The most common cause of an oven not heating is a faulty heating element. You can test the element with a multimeter to see if it's working properly. If the element is faulty, it will need to be replaced.
Check the temperature sensor: Another possible cause of an oven not heating is a faulty temperature sensor. This sensor regulates the oven temperature, so if it's not working properly, the oven won't heat up. You can test the sensor with a multimeter to see if it's working properly. If the sensor is faulty, it will need to be replaced.
Check the oven control board: The oven control board regulates the oven temperature and controls the heating elements. If the control board is faulty, the oven won't heat up. You can test the control board with a multimeter to see if it's working properly. If the control board is faulty, it will need to be replaced.
Check the oven thermostat: The oven thermostat regulates the temperature in the oven. If it's not working properly, the oven won't heat up. You can test the thermostat with a multimeter to see if it's working properly. If the thermostat is faulty, it will need to be replaced.
If you're not comfortable troubleshooting the issue yourself, it's best to call a professional appliance repair technician to diagnose and fix the problem.
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
