Question about Ricoh Aficio CL3500N Laser Printer
I get an error code of SC 411 it says to power off the machine.
  • 95 Answers
That is a color pcu motor error. I would try replacing the color pcu unit first. One of the waste toner augers has backed up with toner causing everything to lock up.
Posted on Aug 02, 2009
How to solve error cade sc 411
Cover of the drum has broken gear, remove the cover, it gets opened when you closr the right door, -Carl
Dec 07, 2015 | Ricoh RICMP2550B Aficio Mp2550B - Digital...
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
Error SC 411 appears
SC411: Separation bias error
-Definition- [B] A separation bias leak signal is detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Discharge brush defective You need the service manual or have a technician fix it. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 15, 2009 | Ricoh (R) Aficio CL3000 Color Laser...
ERROR SC410 ON AFICIO 4506.. ANY HELP APPRECIATED adanquah@gmail.com
I know an SC 411 means this:
SC411: Separation bias leak error
-Definition- [B]
- Possible causes -
• High voltage supply board defective
• Poor connection of the PCU
• Discharge plate defective
Usually a 410 would be in the same ballpark on a Ricoh computer. Unfortunately I don't have the service manuals for 4500 series machines. If you can get a hold of a Ricoh tech in your area, it would be a good idea to rest the power supply and check the pcu as well.
Feb 18, 2009 | Ricoh 4506 Copier
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Error code: 0xc52004 411:lib_micci2.0
This is your solution: s.gif s.gif
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
May 29, 2008 | HP PSC 1610 All-In-One Printer, Scanner...
Error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Feb 09, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio CL3500N Laser Printer Logo
687 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
