Question about LaCie 160GB Safe mobile 160 GB USB Hard Drive
The computer does not detect the drive - LaCie 160GB Safe mobile 160 GB USB Hard Drive
  • 746 Answers
Check your hard drive jumper settings and also check your data cables. I assure if there is not a major fault then your problem will be solved.
Thank You
Posted on Jul 30, 2009
Computer doesnt detect drive
Not exactly The computer detects the drive but windows does not detect the driver. Uninstall the drive in the Device Manager and Restart the computer. This will reinstall the driver..
Nov 29, 2013 | Panasonic (CF-VDRRT1M) CD-RW/DVD-ROM...
Hard drive cannot detect
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 03, 2013 | Computers & Internet
Detect
May 01, 2013 | Transcend USA 120GB Storejet 2.5" SATA -...
My Apollo 250GB USB hard drive can't be detected
It should be in My Computer after you plug it in. If not, then go to control panel and search for new hardware. Click on system in control panel it should be listed under usb. Maybee it needs a new driver.
May 17, 2010 | Imation Apollo (27223) 250 GB USB Hard...
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
I have a constant flashing green light and computer wont detect it
First, try connecting the external drive to another computer. If the second computer fails to detect it, chances are that the housing or, the drive inside have failed. Determining this requires a basic knowledge of external drives. If however the drive is rckognized the the second computer, turn off the first computer and strt it up again (not restart). Then plug your external drive to a usb port directly (not to a hub) and, it should be detected.
Nov 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
LaCie 160GB Safe mobile 160 GB USB Hard Drive Logo
126 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
