SOURCE: I have iPad MC706x/A model can I install ios10 onto this model of ipad
all you have to do here to upgrade:
https://support.apple.com/ios/update
Sorry to tell you that iOS 10 is not compatible with the third-generation iPad, so it will not update to iOS 10.01 like your iPhone 6 because of the hardware is not powerful enough on earlier iPad generations.https://www.cfone.net/apple-ipad-models-generations.html
SOURCE: Can I update my older IPad model mD528c/A to IOS10?
iOS 10 requires at least an iPad 4, sixth generation iPod touch, iPhone 5, or second-generation iPad mini.
I had to delete all data and format the whole system to perform the update. The 4th generation iPad and earlier versions cannot be updated to the current iOS version. If there is no software update function on the iDevice, then you are trying to perform an update to iOS 5 or higher. You will need to connect your device to your computer and open iTunes to update. I did so after which I had to do raid data recovery. But it worked in the end and the system is pulling the updates pretty well. No glitches.
