Question about Black & Decker FP1550T Textured Series Food Processor
My nephew broke the lock clip thing in the bowl to lid area. Can I get a replacement for the whole plastic bowl and lid?
    President:
  • 1,304 Answers
The bowl is part number
MP12-2-200
call 1-866-925-PART
still tracking down lid
Posted on Oct 08, 2009
How does the slide lock on the Cuisinard Custom 11 Food Process go back on?
The main important thing if you have an older style machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle... check the base for the tiny button to double check.
If you put the top on backwards it won't work (at least not correctly) -- but what's worse is that you are likely to break the locking mechanism when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Luckily, bowls and lids are available from Cuisinart... and many times the same bowl/lid was used for different machine numbers (the various models are about the base, not the bowls/lids/blades/etc.)
Dec 15, 2013 | Cuisinart DLC-8S Pro Custom Food Processor
I need a new lid for Braun multipractic 4259. Who stocks one?
Did you find a lid? I have a used one and would gladly send it to you for the cost of shipping from NH.
I warped the bowl for mine in the dishwasher and have since replaced it with a new food processor so would be happy to give away the useful parts (lid, pusher, blade, discs & carrier).
Sep 06, 2009 | Braun Food Processors
My braun 3210 food processor will not work with the large bowl and sharp blade. Will work with the blender/chopper but large bowl the on/off switch cannot be moved. All of the contacts seem lined up - very...
I had a similar problem. Part of the lid had a small piece of plastic chipped away. It was the part of the lid that rotates and locks into the machine base. If the lid is missing a small piece of plastic on where it connects to the base, the machine will not switch on. You can compare the lid for the food processor to the mixing lid and see if the piece that juts into the base is broken at all. If it is order a new lid. There are several online places that still carry them; or try a local parts store.
Aug 20, 2009 | Braun Food Processors
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Cannot lock the top to operate
Get a replacement work bowl lid and/or pusher sleeve - if that does not resolve, replace the whole work bowl.
Nov 29, 2008 | Cuisinart DLC-5 Food Processor
I need a spare lid for Moulinex A77 Masterchef 650 Duotronic
I had the same thing happen to me with a Moulinex model 129 lid. Since it is pretty old the part is obselete. I searched the internet and found a replacement part company for small appliances that had my model lid: < AbtecParts.com > and sold it for about the same as the original manufacturer value of the part $10.00. Perhaps they have your lid or you can find a similar replacement company out there. Doesn't hurt to search sites like ebay also where you might find a cheap used one for parts.
Good luck.
Nov 10, 2008 | Moulinex DG6 Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
Black & Decker FP1550T Textured Series  Food Processor Logo
277 people viewed this question
Top Black & Decker Food Processors Experts
Holly...
Holly...
Jim Thurston
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
