Smeg WDI12 Front Load All-in-One Washer / Dryer
Problem for Smeg WDI12 Front Load All-in-One Washer / Dryer
WDI12C Machine Will Not Drain - Error Code E06
By rotis23 on Nov 24, 2007
Hi All,
My Smeg WDI12C is about 15 months old and will not drain waste water and end of cycle:
- machine displays error code E06 aftre draining phase and before spin
- water is not drained
My first analysis I found:
- the waste tubes are not blocked
- the drain pump filter is free of blockage
- waste water reaches the end of the external waste pipe
I removed the pump it works when tested with 240v applied directly so that is not the problem.
I have removed and checked pressure switch and diaphram is ok and I can blow through small tube and hear air in drum.
Does this sound like a control issue? A similar post on here (for error code E05) said that they rest the unit with guidence from Smeg over the phone (but my warrenty has run out).
Any ideas?
Thanks for any help in advance.
Chris
Comments:
Oct 11, 2008
- Sorry about late reply but turned out to be the pump - checked power to pump using multimeter.
Same Problem
Oct 09, 2008
-   my machine is now half full with water and will not drain the E06 message has popped up and now it just keeps filling up with water i have done all the maunal said to do and it wont drain. can someone tell me how to at least get my clothes out while avoiding flooding my apartment?!?! -   Guest
Mar 25, 2008
-   My machine will wash and spin perfectly but will not dry. I either end up with a hot soggy mess because it did not drain or I get the E06 error code and it stops.-   Benebear
Best Solution
posted on Apr 07, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is a useless machine. I had it and after about 14 months, in quick succession, the pump broke and then the timer broke. A friend with the same machine had the same experience. AVOID!
Solution #2
posted on Nov 25, 2007
Very Helpful)
close
Rank: Wiz
Rating: 83%, 245 votes
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
Was this helpful?
Yes
No
Solution #3
posted on Aug 04, 2009
Not Rated)
ihateproblem
Rank: Apprentice
Rating: 0%, 0 votes
ok this is gr8. Has happened to me as well. Twice. So 22 months into warranty the machine wont go from wash into spin, e06 and all that. Got the engineer who replaced the computer. Sorted- not quite. only lasted for 3 months. Now I am out of warranty but being persistent and threatening consumer action the engineer is coming back tomorrow. Lets see what happens and will update. I think this machine is **** and probably i am saving money for a meile
Was this helpful?
Yes
No
Popular Solutions for Smeg WDI12 Front Load
Questions and Unsolved Problems for Smeg WDI12 Front Load
Do you recommend Smeg WDI12 Front Load All-in-One Washer / Dryer?
Answer
Answer
Hi, Our Smeg WDi 12C starts up on a wash but a few seconds later it stops and comes up with E2, then... (More)
Answer
smeg washer/dryer shows fault msg e14. is this epensive to fix?
Answer
the big drive wheel at the back of the machine is wobbling and throwing the belt off.
Answer
fabric conditioner liquid not being released from tray during washing cycle.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
