Kenmore model 6651576200 dishwashe, normal wash, quick wash,and air dry will light up. Nothing else works on the touch panel. Tried to reset, but got nothing.
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
I suspect for either of these units that the timer control boards are bad.
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
SOURCE: Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
